Fuel Sender Location?
General Maintenance
Old 07-19-2024, 04:06 AM   #1
demerz992 is currently offline
My Year: 96
My Model: z240 talari
My Engine: 5.7 alpha ii
Send demerz992:
Default Fuel Sender Location?
hello! I have a 96 Mariah Shabah 210 with a Mercruiser 5.7 L. Quick simple question: Where the hell is my fuel tank and fuel sender??? I think my fuel sender is stuck. Took it out yesterday and the pin barely moved from full (its deffinetely not full) . I posted a picture of my interior. I believe my fuel sender wiring is fine because the needle pops up when i turn the key. I want to check the sender though! It used to bounce around a little bit (like it was floating) and now its pretty tight..
  • Old 07-19-2024, 02:42 PM   #2
    GregT is currently offline
    My Model: Z275ST
    Gallery Images: 7
    Send GregT:
    Default Re: Fuel Sender Location?
    I'm not certain on your model, but for most the fuel tank is in the middle, under your carpet. My model has a round removeable cover over the fuel sender, so I would expect them to provide some access to the sender unit. Perhaps under your rear seat area? or inside the floor ski locker?
    Old 07-19-2024, 03:02 PM   #3
    My Year: 96
    Send demerz992:
    Hey thanks! i think I agree with you. there seems to be a little square outline under the carpet but i dont wana tear it up. im gonna try the locker.
    Old 07-19-2024, 03:07 PM   #4
    My Model: Z275ST
    Gallery Images: 7
    Send GregT:
    If you haven't also posted this question on the facebook page, I would post there before cutting carpet. That page is so much more active you will get a better answer than waiting here, only a handful of guys routinely view this page.
    Old 07-22-2024, 03:23 PM   #5
    My Year: 96
    Send demerz992:
    UPDATE! I found it! for people with this type mariah, there is about a 1x3 ft piece of plywood with carpet on it that folds up right in front of the engine behind the seat. Fuel sender connection was covered it gunk! cleaned it and works beautifully. check screws in carpet to see if it is screwed down.
    GregT likes this.
    Old 07-22-2024, 03:48 PM   #6
    My Model: Z275ST
    Gallery Images: 7
    Send GregT:
    Thanks for sharing!! You probably saved someone else a lot of headaches in the future! And glad you fixed it!
    #fuel , #fuelsender , #mariah , #shabah
    Sea Fox Fuel Sender Rms72 General Maintenance 2 05-10-2018 11:50 PM
    2004 Sea Fox 230WA Fuel Sender Rms72 Introductions 0 07-17-2016 09:31 PM
    Fuel tank location jchemotti General Maintenance 1 07-13-2012 04:07 PM
    Fuel Gauge or Sender unit andyc Sea Fox - Mariah Talk 5 06-06-2012 01:47 AM
    Changing fuel gauge and sender,windshield parts Richard Keirsey Boating 101 2 09-08-2008 02:58 PM
    There are 349 users
