Question on Quick Connect Inlet Bravo 3
General Maintenance
Old 12-29-2022, 11:56 PM   #1
GregT is currently offline
My Model: Z275ST
Gallery Images: 7
Send GregT:
Default Question on Quick Connect Inlet Bravo 3
As I'm looking over my new boat, I see an inlet tube between the engine and Bravo III housing. It is listed on the parts diagrams as the Inlet Male Quick Connect, shown in the picture. Should something be connected to this? What is it used for?
I have found a few issues where the PO did not install things correctly, so an open tube like this worries me.
Anyone have insight on this thing?
  • Old 12-31-2022, 04:10 PM   #2
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    Default Re: Question on Quick Connect Inlet Bravo 3
    That is the raw water inlet fitting. On my boat a hose is connected between this fitting and the inlet on the raw water pump on the front, starboard side of the engine. Is your raw water coming from a thru hull? If so, is the shown fitting blocked off properly to prevent water ingress?
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 12-31-2022, 09:54 PM   #3
    My Model: Z275ST
    Gallery Images: 7
    Send GregT:
    Thanks for the reply, I'll double check the entire water loop now because it sure seems like something should be connected to it.
    Old 01-02-2023, 06:34 PM   #4
    My Model: Z275ST
    Gallery Images: 7
    Send GregT:
    After a very tight and intimate look under the engine, I found a disconnected hose under the starter which does indeed connect to this fitting fro the raw water intake. ugh, I'm going through each system in detail now to make sure nothing else is incorrect before I fire it up.
    I noticed the trim sensor wire on the outdrive broke, so there is one more thing on the list to do.
    Old 01-03-2023, 12:58 AM   #5
    My Model: Z280
    Good thing you checked, boat would have gone down quickly without that hose connected. Trim sensor is a tough one unless you are changing the bellows.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 01-03-2023, 01:29 PM   #6
    My Model: Z275ST
    Gallery Images: 7
    Send GregT:
    Yeah, always go with your gut feeling if something just doesn't look/seem right.
    I'm going to try to replace bellows and the sensors, watching you-tube videos to see how difficult this task is.
    Old 01-03-2023, 10:02 PM   #7
    My Model: Z280
    Don't bother with exhaust bellows, replace with exhaust tube instead.
    GregT likes this.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Battery quick connect Tlolesen General Maintenance 2 03-19-2019 02:57 PM
    Bravo 1 Shift Issue Question willrev Original Mariah Talk 1 07-09-2014 04:37 PM
    Just a quick prop question. John Rush Prop Talk 8 04-16-2013 02:52 PM
    Quick question Jayson Original Mariah Talk 2 11-15-2009 02:13 PM
    bravo 3 prop question jgreen Prop Talk 5 07-29-2009 04:42 AM
    Total Members: 18,991
    Total Threads: 13,324
    There are 308 users
