Bravo 1 Shift Issue Question
Old 07-09-2014, 12:15 PM   #1
willrev is currently offline
My Engine: 7.4L Bravo
Send willrev:
Default Bravo 1 Shift Issue Question
Have a Talari 240z with the 454EFI engine and Bravo 1 outdrive. Was having a bumping when going from reverse into neutral and sometimes it would not go into reverse. Had to try several times. Had the cables replaced. Doing same. Had cables readjusted. Now the bumping is from forward into neutral. Runs fine at high speeds. Had u joints, bellows, gimbal replaced. Using merc hi performance gear oil. Change every season. Just drained and filled the gearcase with Marvel Mystery oil to soak for a few days. Will refill with fresh oil shortly. I read somewhere not to shift a bravo unless it was running. I didn't know. Mine shifts fine on the trailer into forward. But won't shift into reverse at all on the trailer. That's with it not running. Everyone keeps telling me it is the cone clutch which has to be bought in the entire gear kit $1500 parts and another 500-600 in labor costs. This seems rediculous. I may have 200 hours. Serial # on outdrive is OF407637
  • Old 07-09-2014, 04:37 PM   #2
    Default Re: Bravo 1 Shift Issue Question
    Check the shift fork at drive end. From what I have seen they sometimes break or bend , possibly causing the symptoms you describe.
    As for cost of the cone clutch pack replace , after a bit of online research , price is in the range of fair.
    Bravos aren't cheap , and neither are parts or labor , as you can imagine.
    Bravo 3 time issue thedge2013 Mercury MerCruiser 2 04-22-2014 09:20 PM
    What is a shift interrupter switch ? jchemotti General Maintenance 4 08-03-2012 04:14 AM
    Bravo One Shift Bellows Z212NH Mercury MerCruiser 2 07-26-2010 01:28 AM
    bravo 3 prop question jgreen Prop Talk 5 07-29-2009 04:42 AM
    slow shift into gear bubskunk Original Mariah Talk 0 06-15-2008 11:54 AM
    There are 278 users
