New 2000 Shabah 212 Limited Edition boat
General Maintenance
Old 10-20-2022, 03:58 PM   #1
Praetor is currently offline
My Model: Shaba 212
My Engine: 5.7L Alpha 1
Send Praetor:
Default New 2000 Shabah 212 Limited Edition boat
Hi guys,
I just acquired a 2000 Mariah Shabah 212 limited Edition boat with 13.8 original hours. It hasn't seen water since 2011. It still has antifreeze visible from the last winterization and has been sitting in a barn protected from the elements but very dusty.
I've been going through things and aside from the dust and mildew smell everything seems brand new. I've been doing some general maintenance on it and I'm wondering if there's something Im missing or should be aware of.
Here's what I've done so far:
-Replaced Alpha One Gen2 outdrive impeller, seals and gear oil. Topped off reservoir.
-Fixed leak on outdrive hydraulic trim line. topped off trim reservoir.
-Spent 9 hours cleaning everything with mildew remover and scrubbing canopy
-Replaced prop with 4 blade Quicksilver and hub kit
-Replaced trim Relays on trim pump pack since they were intermittently working
-Mount and supply boat with legal items (Fire extinguishers, life preservers etc.)
-Greased trailer axles
-put new tires on trailer
-Checked Bilge pump, lights, gauges and blower all working properly
Here's what I have planned:
-Will change engine oil/filter in the spring
-Will check spark plugs and wires when I get home
-Clean and buff hull in the spring
Please let me know if there's something else I should be checking or aware of!!
Thanks guys
  • Old 10-20-2022, 07:36 PM   #2
    GregT is currently offline
    My Model: Z275ST
    Gallery Images: 7
    Send GregT:
    Default Re: New 2000 Shabah 212 Limited Edition boat
    WOW! amazing find there! Glad you saved her and are part of the forum now. Also join the two FB groups which are much more active. I bet you are looking forward to getting the boat on the water!
    Old 10-20-2022, 09:37 PM   #3
    My Model: Shaba 212
    Send Praetor:
    Thanks, yeah I’m very excited to get it on the water next spring but I want to make sure I’m not missing anything. I forgot to mention in the first post that I drained all the old fuel out of the tank.
    Can anyone chime in on what I might be missing?
    Old 10-21-2022, 02:29 AM   #4
    pkeane11 is currently offline
    Status: Gold Contributor
    My Model: shabah 190
    My Engine: 4.3 alpha
    Send pkeane11:
    Outdrive Bellows
    Old 10-25-2022, 10:48 AM   #5
    My Model: Shaba 212
    Send Praetor:
    Great, thanks for the tip!
    Member Boat For Sale: 2000 Mariah Z302BR Limited Edition Z302 Mariah Boats For Sale & Wanted 1 11-07-2019 02:16 PM
    Member Boat For Sale: WTS 2000 Z302 limited Edition sceptre155 Mariah Boats For Sale & Wanted 2 05-29-2018 12:24 PM
    Member Boat For Sale: 2000 Mariah Z252 Shabah Limited Edition iralevy Mariah Boats For Sale & Wanted 1 07-14-2016 08:10 PM
    2000 Mariah Shabah 212 Limited Edition NormL Mariah Boats For Sale & Wanted 1 05-09-2012 03:33 PM
    Total Members: 18,991
    Total Threads: 13,324
    There are 361 users
