Hvac pump
General Maintenance
Old 07-07-2020, 02:45 AM   #1
Gearhead is currently offline
My Engine: 7.4 Bravo 111
Send Gearhead:
Default Hvac pump
Hi, I have a 2000 z280 MCC and I have been fixing the plumbing in my heater air condition8ng system. I installed an air bleed valve to. eliminate the manual method bleeding air to make the system work. When I installed the valve it worked, heat moved the temperature up but 8 noticed that the pump wasn’t working. I want to find out if anybody has replaced Has replaced the pump and if so do you know what the specification is with the amount of BTUs ?
Thank you
    SC 23 Bilge Pump 2008SC23 Introductions 3 09-25-2016 03:29 PM
    Raw Water Pump Lee Volvo Penta 3 10-19-2010 03:56 AM
    Is this the fuel pump ? shoup2010 Mercury MerCruiser 6 07-11-2010 02:24 PM
    fuel pump help pls fl_bill Original Mariah Talk 9 07-03-2010 02:25 AM
    looking for fuel pump urim Original Mariah Talk 0 01-18-2010 12:25 AM
    There are 483 users
