Engine bay hatch hydraulic replacement
General Maintenance
Old 10-29-2017, 03:30 PM   #1
1996 Mariah Z252 is currently offline
My Model: Z255 Shabah
Send 1996 Mariah Z252:
Default Engine bay hatch hydraulic replacement
Anybody know where I can some hydraulics for the engine bay of my 255?
  • Old 10-30-2017, 01:38 AM   #2
    GaryDoug's Avatar
    GaryDoug is currently offline
    My Model: Z202
    My Engine: 5.7L Bravo III
    Send GaryDoug:
    Default Re: Engine bay hatch hydraulic replacement
    What hydraulics?? The item in the photos is an electric-operated linear actuator.
    https://greatlakesskipper.com/qmi-gr...-stroke-500-lb
    Old 10-31-2017, 11:17 AM   #3
    Is there anyway I can get them much cheaper? Many the same size but a different brand?
    Old 10-31-2017, 01:30 PM   #4
    GaryDoug's Avatar
    My Model: Z202
    Send GaryDoug:
    There are plenty of linear actuators available that are not marine grade. You would have to measure the stroke of yours and the weight requirement. Search eBay for some. You may be able to find a part number on yours for reference.
    Old 11-28-2017, 08:25 PM   #5
    westport4's Avatar
    westport4 is currently offline
    My Model: Z252 Shabah
    Send westport4:
    What's wrong with them? Not work at all? A bit wonky? Mine where a bit shaky and slow to raise the hatch. Per another post here, I applied a fresh shot (or 3) of grease through each zert and WD40 on the shafts and they work pretty good now. Of course i also had the severely water logged hatch redone and the reduction in weight helped too.
    smds likes this.
    Old 02-22-2018, 12:37 AM   #6
    Unknownmariah is currently offline
    My Engine: 350 magnum
    Send Unknownmariah:
    Progressive automation makes some that are marine grade. About $150 each but they move fast..2.8 inches per second. Im buying them.
    1994 Talari 350 Magnum
    Old 02-23-2018, 01:30 AM   #7
    Send Unknownmariah:
    Found these instead. Not as fast though.
    Old 11-26-2018, 01:20 AM   #8
    1999MariahZ252 is currently offline
    My Model: Z252
    My Engine: 7.4 Bravo III
    Send 1999MariahZ252:
    Mine isnt working either. Thanks for all the info!
    Old 07-03-2019, 05:08 AM   #9
    dexcraft is currently offline
    Send dexcraft:
    Autoclave Composites
    Help on Hydraulic brake actuator replacement ROY850 Original Mariah Talk 15 07-19-2017 04:17 AM
    engine deck lid hydraulic arm donthompson Introductions 2 08-24-2016 12:07 PM
    hydraulic engine cover jsewall82 Original Mariah Talk 8 10-14-2013 04:03 AM
    Help with getting replacement gas strut for hatch stereoman405 Original Mariah Talk 9 06-17-2009 07:13 PM
    jubilee hydraulic hatch lift Gunner Projects 0 06-15-2008 07:49 PM
    Total Members: 18,530
    Total Threads: 12,965
    There are 554 users
