Drain plug on 2001 Shabah 182
General Maintenance
Old 05-29-2019, 01:00 PM   #1
Tlolesen's Avatar
Tlolesen is currently offline
My Model: 182
My Engine: 4.3 merc
Gallery Images: 3
Send Tlolesen:
Default Drain plug on 2001 Shabah 182
The drain plug is kind of loose when I insert or remove the plug and one screw won't tighten. I was going to remove and clean then rotate what should I use for a sealant behind when I reinstall and what if anything in the new screw holes.
  • Old 05-30-2019, 01:14 AM   #2
    Levinz11 is currently offline
    My Year: 2006
    My Model: SX20
    My Engine: 4.3 Alpha
    Send Levinz11:
    Default Re: Drain plug on 2001 Shabah 182
    3M 5200
    Old 05-30-2019, 01:20 AM   #3
    IF it is rotted around the bung hole, you may have install a backer plate along with using the 3M 5200 sealant. Just dont block the drain.
    Old 05-30-2019, 08:11 AM   #4
    pole trick is currently offline
    My Model: 180 Shabah
    My Engine: 4.3 Merc
    Send pole trick:
    If lower transom that soft....boat may be junk or need new transom. May not be safe to run any more.. it will sink real fast when drive rips off and tears hole in boat. My freinds dad had marina seen a few that tore off, outboard and IO. Boat looked great, but rear end rotted off.
    Old 05-30-2019, 11:52 AM   #5
    Tlolesen's Avatar
    My Model: 182
    My Engine: 4.3 merc
    Gallery Images: 3
    Send Tlolesen:
    Is there something behind that the plate is attached to or is it just a flat plate
    Drain plug Kerberajen Original Mariah Talk 10 06-19-2020 05:56 PM
    211 drain plug DCA Original Mariah Talk 3 09-15-2017 06:59 PM
    drain plug Dbergster Introductions 2 08-17-2016 03:40 PM
    '96 Talari drain plug mike523 Original Mariah Talk 2 03-29-2016 12:51 AM
    drain plug LED Oregondunes Other For Sale 14 08-06-2014 10:38 PM
    There are 375 users
