Z204 Ignition Switch 1998
General Maintenance
Old 07-06-2017, 04:33 PM   #1
GTSJK is currently offline
My Model: Z204 Jubilee
My Engine: 4.3L Alpha
Send GTSJK:
Default Z204 Ignition Switch 1998
My ignition switch now turns 360 degrees when I turn the key and it needs to be replaced. I have a 4.3L Alpha One engine.
Wondering 2 things:
1) Is there a replacement part # anyone can provide for this?
2) Would love to keep the original Mariah Key and use it, is there a way to repair the old ignition switch and if not, is there a way to "re-key" a new switch if I buy it so I can use my old Mariah key?
Any help greatly appreciated!
  • Old 07-06-2017, 05:12 PM   #2
    My Model: Z202
    Send Firestone:
    Default Re: Z204 Ignition Switch 1998
    Check the threads. I thought I saw a post about this winter/spring that they were able to buy a new swith and reuse the key.
    John
    Old 07-06-2017, 05:15 PM   #3
    Send GTSJK:
    Saw a link to someone who might supply keys and cylinders but it was from 2014. Went to send email and it kicked it back saying box was full, which I am guessing means they may not be answering that box anymore. Email address was:
    [email protected]
    Old 07-06-2017, 05:19 PM   #4
    My Model: Z202
    Send Firestone:
    Not sure he is around any more. You might try this as a last option.
    Original mariah key
    John
    Old 07-07-2017, 07:46 PM   #5
    Mwb712 is currently offline
    My Model: 182 Barchetta
    My Engine: MCM 4.3 Litre LX
    Send Mwb712:
    Wondering 2 things:
    I bought a four pinned ignition switch from Advance Auto Parts for less than $10.00. Took apart my Mariah key cover with a chisel, bent back round metal, replaced the key, use J-B weld for metal. Looks like new! On the switch, you might have to remove a backup nut for a tight fit! Remove the wires in exact order or you might have wires in wrong places like I did ( On is in the Accessories position ). DO NOT BUY AUTOMOTIVE IGNITIONS FOR MARINE PRODUCTS! Found out the hard way had to replace the switch the following spring!
    Sent from my iPad using Tapatalk
    Thank you Mwb712 for this useful post!
    Firestone (07-07-2017)
    Old 07-17-2017, 11:34 PM   #6
    Send GTSJK:
    How do you know the 4 pin one is the correct switch? I saw some that looked like 3 pin and some that maybe were 5 pin. I haven't pulled the old one off yet, and was hoping to buy the part in advance to this as boat is remotely located.
    Old 07-18-2017, 12:43 PM   #7
    Send Mwb712:
    Look at the back of the switch and see how many wires are connected to it will tell you how many pins it is.
    Old 07-19-2017, 04:38 AM   #8
    My Model: Z276
    Send Brian Belcher:
    I found them on the Book of Faces and sent a message. If and when I hear back, I'll let you know. I need a key too
    Old 04-30-2018, 05:24 PM   #9
    kevins_1323 is currently offline
    My Model: Shabah 198 SE
    My Engine: 5.7 / Alpha 1
    Send kevins_1323:
    Any luck? I broke my key and would LIKE to find a real Mariah key.. Emailed this guy as well,, but thought I Would see if you had any success getting in contact with him..
    Old 06-06-2021, 02:29 AM   #10
    Send Mwb712:
    If you have the original key (the fob) mostly, the fob does come apart. There’s a seam on the edge that can be split apart to release the key. Apply some epoxy for metal the “glue” it back together. If you bend the plate, simply hammer it out between the flats of two hammers. Apply some epoxy on the edge, then add some weight until it cures. Good luck and I hope that helps
    Lewy likes this.
    Ignition switch Threejakes Original Mariah Talk 7 06-20-2016 03:25 PM
    Ignition Switch blatt88 General Maintenance 0 09-27-2014 01:38 AM
    Ignition Key Switch? Chickman Original Mariah Talk 4 04-29-2014 06:15 PM
    New Ignition Switch - Won't Start Dsg03svt Original Mariah Talk 6 04-11-2012 01:46 PM
    Ignition switch Provo Original Mariah Talk 1 08-15-2009 09:21 PM
    There are 300 users
