Unsure where this wire goes.
General Maintenance
Old 06-10-2017, 12:36 AM   #1
Silencio82 is currently offline
My Model: Shabah
My Engine: 4.3 vortec 180
Send Silencio82:
Default Unsure where this wire goes.
Fixing up a boat my friend said I could have if I get it running. It is a 96 miriah shabah with a 180 hp 4.7 L vortec. When I turn it over a Solonoid clicks. I'm wondering if I should replace it or not. There is this one wire near it and I'm not sure where it goes or if it is unnecessary. This boat probably has less than 100 hours use since he bought it. And he took it to a mechanic who ran it about 6 months ago. The mechanic took it out on the lake to drive it around and see if there were issues.
Firestone and ROY850 like this.
  • Old 06-10-2017, 12:42 AM   #2
    My Model: Z202
    Send Firestone:
    Default Re: Unsure where this wire goes.
    Hopefully some of the gear heads here can help you. Good luck on your project.
    John
    Old 06-10-2017, 01:17 AM   #3
    My Model: Shabah
    Send Silencio82:
    Thanks bro!
    Old 06-15-2017, 03:00 AM   #4
    1996 Mariah Z252 is currently offline
    My Model: Z255 Shabah
    Send 1996 Mariah Z252:
    I'm not sure but that looks like it may be a alternator cable. (learned from experience.) This could also mean it's a negative cable. But, take a voltage tester and turn some stuff on one by one and see if you get and readings. For example, If you flip the bilge pump switch on and get power you know its to the bilge pump. (obviously) you should definitely replace the solonoid. It could either be the solonoid, corroded battery cables and/or terminals or a bad battery.) most of the time though it's the solenoid. (I've had mine replaced at least twice in the last 3 years. Hope that helps!
    Wire near outdrive steve.barnett Original Mariah Talk 10 09-02-2012 08:54 PM
    Hot wire on alternator Captain D Original Mariah Talk 4 07-18-2012 01:58 AM
    Elusive Alternator Wire Brewfixer Original Mariah Talk 10 05-17-2011 06:13 AM
    short in this wire please help. My_My_My_Mariah Mercury MerCruiser 3 09-13-2009 11:57 PM
    Unknown Wire 2000Z272 Mercury MerCruiser 9 06-21-2009 12:42 AM
    There are 245 users
