How to drain my old gas?
General Maintenance
Old 02-29-2016, 01:08 AM   #1
62 driver is currently offline
My Model: 202 Shaba
My Engine: 4.3 L
Send 62 driver:
Default How to drain my old gas?
I have a 1995 202 v6 and need to drain all the gas out of the tank. I am a shade tree wrench. Any ideas on draining the tank. Is their a drain plug? If so where? I tried to siphon it out with a hose. No luck. Thanks Dave
  • Old 02-29-2016, 03:17 PM   #2
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    Default Re: How to drain my old gas?
    I doubt there is a drain plug. I had to do the same on an old boat, not a Mariah. The best method I found was removing the fuel sender and dropping in an electric fuel pump with a long hose that I placed into multiple 6 gal cans. As always, be careful working around fuel. I placed the battery for the fuel pump outside the boat, wrapped a wet towel around the fuel sender opening and had a fire extinguisher at the ready. Good luck.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 06-08-2016, 09:55 PM   #3
    My Model: 202 Shaba
    My Engine: 4.3 L
    Send 62 driver:
    Where is my gas tank located at?
    Old 06-21-2016, 09:24 PM   #4
    My Model: 202 Shaba
    My Engine: 4.3 L
    Send 62 driver:
    Found the tank sender and removed it to suck the gas out. Drained the fuel filter. Put new gas in with a new battery. Started right up after sitting 4 years. Did a shake down run. Could smell electric smoke smell around the passenger feet area. Just below the glove box. Stopped after 30 minuets. Ideas?
    Old 06-13-2017, 09:50 PM   #5
    My Model: Z202
    Send Firestone:
    Did you ever find out the issue?
    John
    drain plug LED Oregondunes Other For Sale 14 08-06-2014 10:38 PM
    Cooler Drain jeffro788 Original Mariah Talk 2 06-21-2010 02:52 PM
    No drain in ski locker tmonson Original Mariah Talk 5 05-07-2010 09:03 PM
    Oil Drain Kit 272man Mercury MerCruiser 2 05-22-2009 12:33 PM
    Ski well drain/bilge drain jhaag41 General Maintenance 1 07-17-2008 10:09 PM
    There are 235 users
