Cooler Drain
Old 06-17-2010, 05:05 PM   #1
jeffro788's Avatar
jeffro788 is currently offline
My Model: 180 Shabah
My Engine: 4.3L Alpha One
Send jeffro788:
Question Cooler Drain
Hey guys, I was wondering if anyone has had to fix the drain on their cooler in the dash. I noticed it wasn't draining so I put a little water and air to the hole and discovered that where the drain tub was connected to the hull, the plastic piece had broken off with the tub still attached so the cooler will be draining into the hull and any water that comes in thru the hole from outside the boat will go in the hull also. I am not sure how to get the interior side panel out to find a way to run another hose and have it drain out the side. I may just have to plug the drain in the cooler and drain it into something when needed.
I hope someone can make sense of what I just said, b/c I am not sure I know what I said.
  • Old 06-19-2010, 05:59 PM   #2
    dieselwiezil is currently offline
    My Model: 2000 Mariah 212 5.7V8 Mercruiser Alpha I 21p mirage plus 48-13702
    Send dieselwiezil:
    Default Re: Cooler Drain
    every season I run about an ozarka bottle of water/ chlorox to keep it from mold. You Might be able to reach it from the bow flip up seat. If not just let it run into the hull and if excess is there it will bilge out
    2000 Mariah 212 Mercruiser 350
    2002 F150 Supercrew
    1996 F250 Diesel lots of power goodies.
    "Out of everything I have, I still prefer riding MARIAH"
    Old 06-21-2010, 02:52 PM   #3
    jeffro788's Avatar
    Send jeffro788:
    my problem is fixing the drain tube to where it will drain out of the hull, the nozzle that is attached to hull broke off where the tube connects. The cooler now drains in the floor b/c there I had to take the tube out. I am just trying to see if there is a way that I can put another nozzle on the hull so i can hook the tube back up and drain the water out
    power steering cooler water draining m&mmariah General Maintenance 0 01-26-2010 03:23 AM
    Swim Platform... cooler, livewell, ??? kylakerat Original Mariah Talk 6 03-22-2009 03:24 PM
    Clogged in-floor cooler & ski locker Danny Campbell General Maintenance 1 07-24-2008 09:20 AM
    Ski well drain/bilge drain jhaag41 General Maintenance 1 07-17-2008 10:09 PM
    Looking for a cooler lid ceb Original Mariah Talk 1 05-19-2008 08:13 PM
    There are 257 users
