Depth Finder Upgrade?
General Maintenance
Old 08-12-2015, 11:55 PM   #1
ipgregory's Avatar
ipgregory is currently offline
My Model: Z308
My Engine: Twin 5.0L EFi/Alpha 1s
Send ipgregory:
Default Depth Finder Upgrade?
Has anybody with a Factory fitted Lowrance 3500 Depth gauge and in hull transducer upgraded to something newer?
Have a dead 3500 I need to replace but not sure what transducer will fit best in the original spot? Looking at maybe a Lowrance 3800 or Fariah at the moment unless anybody has any better suggestions?
TIA
Ian
2000 Z308 MCC, twin 5.0L
2004 SC21, 4.3L (Sold)
  • Old 08-31-2015, 09:14 PM   #2
    pllevine's Avatar
    pllevine is currently offline
    My Model: 202 Shabah
    My Engine: 5.0L Alpha
    Send pllevine:
    Default Re: Depth Finder Upgrade?
    I have the same issue... I think that the transducer is working but my 3500 head unit is messed up. I know they use a 192kHz signal and everyone now uses a 200kHz transducer.
    I think that the only way to go is to buy a new head unit and transducer, but am not sure how to get the old one out of its mounting location in the bilge under the engine. I was looking at the Faria and the Hawkeye in-hull versions. I really don't want a transom mount because I don't want to put any more holes in the transom.
    Anyone out there have any ideas?
    Phil Levine
    1998 202 Shabah
    Old 09-12-2015, 07:03 AM   #3
    pllevine's Avatar
    Send pllevine:
    Hi:
    Just to throw this info into the thread... There are three OEM Lowrance 3500 complete units with in-hull transducers on eBay now for $320.00 per. I would say that the price is 3X what they're worth but if you want the original equipment replacement, then look here:
    http://pages.ebay.com/motors/link/?n...114278&alt=web
    Phil Levine
    1998 Mariah 202 BR
    Phil Levine
    1998 202 Shabah
    Old 08-09-2020, 08:30 PM   #4
    DanGundrum is currently offline
    My Model: Shabah Limited Edition
    My Engine: 5.7 liter Mercruiser
    Send DanGundrum:
    I may have to replace the depth finder screen on the dash. Anyone know where I might be able to do it in the least expensive way?
    Old 08-18-2020, 05:07 PM   #5
    Not sure where you'll find a matching replacement unless you can get Lowrance or who ever makes yours to repair the existing one. Youll probably end up with an entire new setup, transducer and all. Do a search on Google or eBay or similar. They are not unique to just Mariah.
    Big thing to be careful of is that dash. That plastic is old and brittle.
    Depth Finder diablo18 Original Mariah Talk 14 05-28-2013 02:15 PM
    Depth finder gauge Jaztwnz General Maintenance 11 05-15-2013 06:39 PM
    Depth finder replacement jjk61083 Original Mariah Talk 2 07-19-2012 06:25 PM
    Depth Finder jchestnutt Introductions 1 05-06-2012 12:16 AM
    Depth finder joeboat Original Mariah Talk 1 08-21-2009 12:54 AM
    There are 325 users
