Depth finder replacement
Old 07-09-2012, 05:46 PM   #1
jjk61083's Avatar
jjk61083 is currently offline
My Model: 202 Shabah
My Engine: 5.0L Alpha One
Send jjk61083:
Default Depth finder replacement
I am wanting to replace my Lowrance 3500 depth guage with a new Faria guage. I am having trouble locating the Faria with gold bezel and white background to match my other guages. Anybody have a clue if the Lowrance gold bezel will work with the Faria guage? Thanks.
Jim
1998 Mariah 202 Shabah
5.0 Alpha One
  • Old 07-09-2012, 10:34 PM   #2
    Default Re: Depth finder replacement
    Try checking out Great Lakes Skipper on eBay. They are the most likely source for Mariah gauges.
    Old 07-19-2012, 06:25 PM   #3
    jjk61083's Avatar
    Send jjk61083:
    Ok...no luck finding a white face Faria gauge with gold bezel. Here's what I ended up doing, just in case anybody else runs into the same situation. I found a new Faria in their "dress white" style on eBay. After I removed the old Lowrance bezel, I decided to cut out the inside and see if possibly the outside gold ring would fit over the new Faria. I used my Dremel with a small grinding bit to cut it out to about 1/16" of an inch from the edge. I then switched to a small round sanding bit and smoothed it out just to the edge of the inner ring. To my delight, the old gold bezel ring snapped perfectly onto the new Faria gauge!
    mikeyt likes this.
    Jim
    5.0 Alpha One
    Thank you jjk61083 for this useful post!
    Mic22 (04-03-2015)
    Anybody having trouble with their OE depth finder? Purple_Shabah Original Mariah Talk 28 06-29-2016 01:51 PM
    Depth Finder jchestnutt Introductions 1 05-06-2012 12:16 AM
    Depth finder inop theeasynine Original Mariah Talk 24 09-06-2010 05:45 PM
    Depth Finder Problem?? hatran Introductions 2 05-20-2010 06:18 PM
    Depth finder joeboat Original Mariah Talk 1 08-21-2009 12:54 AM
    There are 355 users
