V-drive vs. I/o
Chit Chat/Off-Topic
Old 09-11-2014, 11:03 AM   #1
Txtruckerpaul's Avatar
My Model: Z240 talari
My Engine: 7.4 bravo III
Send Txtruckerpaul:
Default V-drive vs. I/o
This is not related to Mariah whatsoever, that's why I'm posting this in here. I have the opportunity to buy a Gibson houseboat. It is equipped with twin chrysler 360's with v-drives. I've never dealt with a v-drive before, so I would like to hear from someone that knows about them and the advantages/disadvantages. Are they better or worse than an inboard/outboard such as a mercruiser?
  • Old 09-11-2014, 02:46 PM   #2
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    Default Re: V-drive vs. I/o
    V-drives are a lot simpler than outdrives, many fewer moving parts. The downside is they are no where near as manueverable, particularly in reverse, as you are relying on water moving past rudders rather than outdrives for steering. V drives are more compact than standard shaft drives, it allows the engines to be located closer to the stern rather than amidships.
    Txtruckerpaul likes this.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 09-12-2014, 01:24 PM   #3
    HudsonRiverSteve hit the nail on the head. They are much more simple from a mechanical standpoint, but have some notable downsides, as steve mentioned. Another pretty important downside is that you need to be much more aware of depth and the risk of running aground. You can run an outdrive into the ground and not do too much damage thanks to the protective skeg. Run a v-drive shaft into the bottom, your propeller's going to be toast, and that just might be where the damage begins.
    If you boat in deep water, a v-drive might not be bad, if you don't run the risk of grounding. You can always install a bow or stern thruster to overcome the maneuverability issues. After all, it's just money, right ?!?
    However, with twin engines and a little practice, you might be really impressed with the maneuverability! Keep us updated!
    Old 09-12-2014, 01:40 PM   #4
    Send Txtruckerpaul:
    Thank you guys for the input. The lake I would put it in has a decent depth to it, so running aground wouldn't be an issue. This is the type of boat that would be left in a rented slip and only removed from the water once in a great while for bottom side repairs. The boat is a twin engine, two props and a rudder, so I would need to learn how to move it around at slow speeds using the engines. I guess a bass boat trolling motor could be mounted up from for a bow thruster, lol.
    Seems to be a good solid boat, well taken care of, always parked in a covered slip and owner said he had a bottom job done a year and a half ago. It's basically a floating rv, with all the amneties
    Old 09-12-2014, 07:15 PM   #5
    I'll bet it'd be a lot of fun! If it's solid, well maintained, has the amenities you want, and the price is right, go for it!
    This video goes over two of the best pieces of advice I've heard from twin engine boaters. The "Thumb Method" and "Bumps". Once you get the hang of this, it'll be easy!
    Quick Tips with Captain Frank-docking a twin engine - YouTube
    And always remember, never approach a dock any faster than you'd want to hit it.
    Old 09-12-2014, 07:50 PM   #6
    Send Txtruckerpaul:
    That's a big help, shabah. Great video, thanks!
    Old 09-20-2014, 06:14 PM   #7
    Andy b's Avatar
    Andy b is currently offline
    My Model: Diablo 180
    Gallery Images: 9
    Send Andy b:
    Now there's words of wisdom
    I know a couple of people who could use that as a fender sticker.......lol
    out drive mikstick Original Mariah Talk 3 03-22-2012 06:16 PM
    Drive Shower. scubydo Original Mariah Talk 4 08-16-2011 07:05 PM
    out drive not coming up tombail Original Mariah Talk 3 04-29-2011 02:08 AM
    drive problems candanewell Boating 101 6 06-01-2010 02:41 AM
    Greasing Drive jakejorgenson General Maintenance 0 02-03-2009 03:40 AM
    There are 300 users
