Is this hull design
Chit Chat/Off-Topic
Old 04-08-2017, 03:32 PM   #1
Hunter12345's Avatar
Status: Silver Contributor
Gallery Images: 2
Send Hunter12345:
Default Is this hull design
Is this arc in the hull typical on mariah's?? On the aide shot of you zoom in towards the back, the arc follows thru the outside, im hoping this is the way she is and not warping due to trailer bunks.
Photos are from transom, then from bow. The very middle where the drain plug is does not arc.
'98 shabah 180
5.7l 350 mag
Bravo III
  • Old 04-08-2017, 03:38 PM   #2
    Gallery Images: 2
    Send Hunter12345:
    Default Re: Is this hull design
    Seem to taper down the last 12" or so
    '98 mariah shabah 180
    5.7l 350 mag
    Bravo III
    '98 shabah 180
    5.7l 350 mag
    Bravo III
    Old 04-08-2017, 06:34 PM   #3
    Gallery Images: 2
    Send Hunter12345:
    K well, apparently theyre like that, almost like a built in planing tab im told.
    5.7l 350 mag
    Bravo III
    '98 shabah 180
    5.7l 350 mag
    Bravo III
    Old 04-08-2017, 10:37 PM   #4
    GaryDoug's Avatar
    GaryDoug is currently offline
    My Model: Z202
    My Engine: 5.7L Bravo III
    Send GaryDoug:
    I am not sure what you are talking about. Do you mean there is a slight depression (upward) in the hull about 1/4 way forward of the transom? Or something else? I think mine has a similar fault/feature(?). I thought it was damaged by a fork lift.
    Old 04-09-2017, 06:50 AM   #5
    Gallery Images: 2
    Send Hunter12345:
    Its hull design. Almost like a built in smart tab. The images are frombow and transom, on trailer. I thought the weight, and the generic trailer was causing hull warp.
    5.7l 350 mag
    Bravo III
    '98 shabah 180
    5.7l 350 mag
    Bravo III
    Old 04-09-2017, 06:55 AM   #6
    Gallery Images: 2
    Send Hunter12345:
    Honestly had a panic attack when i saw it, i just thought seriously?? Take good care of it how did i miss that? My buddies 98 sea ray has the same thing just not as miuch. If anybody can post a pic of their hull id appreciate it!
    5.7l 350 mag
    Bravo III
    '98 shabah 180
    5.7l 350 mag
    Bravo III
    Old 04-09-2017, 06:58 AM   #7
    Gallery Images: 2
    Send Hunter12345:
    5.7l 350 mag
    Bravo III
    '98 shabah 180
    5.7l 350 mag
    Bravo III
    Old 04-09-2017, 12:15 PM   #8
    GaryDoug's Avatar
    My Model: Z202
    Send GaryDoug:
    Yes, mine is the same, so either we both have the same defect or it was in the design. I saw that first when I was buying the boat. The previous owner (for only a year) said he never noticed it. It wasn't a big deal to me. I assumed it was done by the forklift that was used at the high-and-dry marina where the boat was stored for almost a year. But I think the forks are usually a lot longer now that I remember seeing them elsewhere. For what it's worth, I have the original custom trailer and the bunks go all the way to the end of the boat.
    Old 04-09-2017, 12:48 PM   #9
    GaryDoug's Avatar
    My Model: Z202
    Send GaryDoug:
    OK, I am pretty sure I see it in one of the factory floor photos in here, page 3:
    http://www.mariahownersclub.com/foru...hure-hires.pdf
    Hunter12345 and Firestone like this.
    The Following 2 Users Say Thank You to GaryDoug For This Useful Post:
    Firestone (04-11-2017), Hunter12345 (04-09-2017)
    Wanted: Carling Switch Covers Curved Design 99 Mariah 258 Mariah Parts For Sale & Wanted 2 07-14-2014 02:17 AM
    Horn Design/Mounting problem DFZ272 Original Mariah Talk 0 03-23-2012 09:04 PM
    I this the same hull CARL SWINDLE Sea Fox - Mariah Talk 1 06-04-2010 02:02 PM
    Need help with hull ID mjhinno Introductions 9 10-05-2009 10:31 PM
    Barchetta Hull Design boarder1010 Original Mariah Talk 8 07-08-2008 06:20 PM
    There are 252 users
