Depth finder woes
Boating 101
Old 07-19-2010, 04:21 AM   #1
NogginDoc's Avatar
NogginDoc is currently offline
My Model: Z 255 Shabah
Send NogginDoc:
Default Depth finder woes
So, my depth finder still doesn't work after it was replaced by the maintenance shop where I bought the boat.
They removed the original Lowrance depth finder gauge and transducer (which was demolished after the boat was loaded on its trailer where the bunks were too long and extended too far behind the hull of the boat). They replaced it with a Hummingbird depth finder which apparently had the same dimensions to fit in the factory opening for the gauge. However, they sealed up the old holes where the original factory transducer was located, and installed the new transducer closer to the outdrive (about half the distance from the factory location towards the outdrive). I'm not sure if this make a difference from any cavitation, etc., or if it's too close to the outdrive.
At any rate, it doesn't work while the motor is on. It only reads the depth when the engine is off and when it's floating still in calm water. As soon as the engine is turned on, the depth readings are off the scale showing 500+ feet depths (my lake is lucky to get 50ft deep).
Anyone know where the best place to locate the transducer? Should I have a hull mounted "puck" transducer installed? I really need to have this depth finder working because my lake has several areas where there's shoals and boulders under the water which are not marked very well by any buoys.
Thanks.
NogginDoc
1996 Shabah z255
  • Old 07-19-2010, 04:35 PM   #2
    Default Re: Depth finder woes
    Transom mount transducers can be affected by turbulence generated by the boat's hull so have to be carefully placed at the correct height to work properly. Even then, it wont always work perfectly. Check to see if the transducer is 'locked down' into position. If it isn't it will flop around at any sort of motion & give wild depth readings.
    If you are considering an in-hull transducer you will likely have better results but....let a pro install it.
    Depth Finder Problem?? hatran Introductions 2 05-20-2010 06:18 PM
    Depth Finder works the first minutes then mad ebb8827 Original Mariah Talk 8 03-23-2010 03:52 PM
    Depth finder joeboat Original Mariah Talk 1 08-21-2009 12:54 AM
    Aftermarket Depth Finder Suggestions? stereoman405 Original Mariah Talk 0 06-25-2009 05:33 AM
    depth meter harry van kesteren Original Mariah Talk 6 09-13-2007 10:14 AM
    There are 237 users
