Black "sut" around outdrive
Boating 101
Old 06-21-2016, 11:31 AM   #11
Hunter12345's Avatar
Status: Silver Contributor
Gallery Images: 2
Send Hunter12345:
Default Re: Black "sut" around outdrive
Originally Posted by Brian Belcher View Post
I discovered on mine, the hot wire for the choke comes directly from alternator. The connector is a cheap, push on barrel type and mine had popped off. Put it back on to only have it do it again. The second time around, I slightly crimped/crushed the fitting.
https://vimeo.com/171560821
Heya fellas! Great weekend on the water! Maybe some of the more knowledgeable guys has an answer? In my drive lube monitor, there seems to be a 1/16" layer of "foam" the lube underneath, is still dark blue. I dont want to damage the bravo 3 as it is very expensive to replace, see image, maybe someone has had a similar experience? Can the lube be overheated?
The black on the outdrive was a 1 time occurrence.
'98 shabah 180
5.7l 350 mag
Bravo III
  • Old 06-21-2016, 03:21 PM   #12
    dafucwuzat is currently offline
    My Model: talari 221
    My Engine: merc 5.7 b3
    Send dafucwuzat:
    Only thing I can come up with is if you changed drive oil and didn't refill it from bottom. You need to pump it in from bottom for initial refill. May have air bubbles coming back up tube from voids in case during running.
    Old 06-21-2016, 09:43 PM   #13
    Gallery Images: 2
    Send Hunter12345:
    Your the 4th person to say that. No cause for concern, apparently the b-3 run hot, and it forces impurities and bubbles out into the drive lube monitor.
    '98 shabah 180
    5.7l 350 mag
    Bravo III
    Old 06-25-2016, 01:48 PM   #14
    Gallery Images: 2
    Send Hunter12345:
    As you can see how the mariah is docked, it seems to be a very difficult process to have my kids board the boat and not use my back bench seats as a step!!! My daughters boyfriend did it twice i almost threw him overboard. Id like to keep the original seats etc in top shape but seems to be a challenge getting in and out without stepping on the seats!
    Unless i remove the cushion on the bow and have people board there.
    '98 shabah 180
    5.7l 350 mag
    Bravo III
    Member Boat For Sale: "Last Red Cent" 1999 Z302 502 mpi / Bravo Three Viper Red Limited Edition Boatcrazy Mariah Boats For Sale & Wanted 9 07-24-2015 09:51 PM
    Ultra Rare 1993 "The Mick" Mariah Z2000 up for Auction ShabahZ280 Mariah Boats For Sale & Wanted 10 07-01-2013 06:03 PM
    The official "What's your favorite original Mariah accessory" thread! stereoman405 Original Mariah Talk 23 11-10-2011 05:04 PM
    Outdrive "Click"ing? SEMIJim Mercury MerCruiser 10 08-08-2009 01:00 AM
    There are 297 users
