Black "sut" around outdrive
Boating 101
Old 06-05-2016, 06:04 PM   #1
Hunter12345's Avatar
Status: Silver Contributor
Gallery Images: 2
Send Hunter12345:
Default Black "sut" around outdrive
Can anyone explain this black around the outdrive? Would this be from exhaust? I flooded her once by accident.
'98 shabah 180
5.7l 350 mag
Bravo III
  • Old 06-06-2016, 05:43 PM   #2
    dafucwuzat is currently offline
    My Model: talari 221
    My Engine: merc 5.7 b3
    Send dafucwuzat:
    Default Re: Black "sut" around outdrive
    Looks like exhaust at idle. Your bellows probably allow it to come out of them a little and its in that cave like area to trap it in
    Hunter12345 and Firestone like this.
    Old 06-07-2016, 08:15 PM   #3
    My Model: Z276
    Send Brian Belcher:
    Running VERY rich. Good thing is you know it's at idle so you can adjust idle air mixture screws
    Hunter12345 likes this.
    Old 06-08-2016, 10:33 PM   #4
    Gallery Images: 2
    Send Hunter12345:
    It idles good, but sputtered once or twice when i hit the throttle. I know carbs have a slight delay compared to efi, air fuel mixture, im not very mechanical with engines but not afraid to learn. Unfortunately, i wouldnt know how to adjust the screws, how much to turn, and when is perfect, ill have to call the merc people to come out at the lake. I put in premium gas, should i be running regular?
    '98 shabah 180
    5.7l 350 mag
    Bravo III
    Old 06-12-2016, 07:39 PM   #5
    Gallery Images: 2
    Send Hunter12345:
    Brian, would it be an automatic choke issue? Ill know more when i get to the lake, im going to run it up on the trailer, maybe the choke is closing too much on start up?
    I know one guy with a 454 carb said if your not running cold weather you can "wire open" the automatic choke, funny thing is, it doesn't idle up higher on start.
    '98 shabah 180
    5.7l 350 mag
    Bravo III
    Old 06-13-2016, 01:55 PM   #6
    My Model: Z276
    Send Brian Belcher:
    Yep. I bet it's your choke. Is it electric ?
    Old 06-14-2016, 08:48 PM   #7
    Gallery Images: 2
    Send Hunter12345:
    So not sure on the 95' mercruiser 350 4 barrel, im not positive yet if its a "heat" activated choke with the coil spring that opens it when it get hot?
    I seen how that one operates, but never seen an electric choke.
    The wierd thing is it doesnt idle up in neutral, just starts, idles fine at operating idle. Wierd, maybe and hopefully its a one time occurance, splashing it again this weekend, the kids are due for some punishment on the tubes. Haha!
    '98 shabah 180
    5.7l 350 mag
    Bravo III
    Old 06-15-2016, 01:20 AM   #8
    Send dafucwuzat:
    Hunter, if you have the electric choke, which I'm GUESSING you do, it probably has 2 screws on side that you can loosen, then rotate adjustment. Best thing I think at this point is YouTube. Every carb known to man can be found on there checking and adjusting choke.
    Old 06-15-2016, 11:12 AM   #9
    Gallery Images: 2
    Send Hunter12345:
    Thanks buddy, ive watched a bunch, theres a good 5 part series about carbs, took about an hour to get through them, but well worth it.
    '98 shabah 180
    5.7l 350 mag
    Bravo III
    Old 06-16-2016, 04:20 PM   #10
    My Model: Z276
    Send Brian Belcher:
    I discovered on mine, the hot wire for the choke comes directly from alternator. The connector is a cheap, push on barrel type and mine had popped off. Put it back on to only have it do it again. The second time around, I slightly crimped/crushed the fitting.
    Member Boat For Sale: "Last Red Cent" 1999 Z302 502 mpi / Bravo Three Viper Red Limited Edition Boatcrazy Mariah Boats For Sale & Wanted 9 07-24-2015 09:51 PM
    Ultra Rare 1993 "The Mick" Mariah Z2000 up for Auction ShabahZ280 Mariah Boats For Sale & Wanted 10 07-01-2013 06:03 PM
    The official "What's your favorite original Mariah accessory" thread! stereoman405 Original Mariah Talk 23 11-10-2011 05:04 PM
    Outdrive "Click"ing? SEMIJim Mercury MerCruiser 10 08-08-2009 01:00 AM
    There are 353 users
