best towing vehicle?
Trailering and Tow Vehicles
Old 05-27-2014, 10:45 PM   #11
Default Re: best towing vehicle?
Good video of a locking diff
http://youtu.be/q-rQTHMVAuw
  • Old 07-08-2014, 07:40 PM   #12
    wery7's Avatar
    wery7 is currently offline
    My Model: 235 Davanti
    My Engine: 502 Bravo One
    Send wery7:
    The quickest, easiest, and cheapest will likely be throwing bags of sand or salt (for water softener - then you always have it ready) in the back for added weight. You likely have an all season tire as well on there, so you could upgrade to more of an agressive tread tire which would help a little, but not a ton. If all else fails, you are looking at a 4X4 unfortunately.
    But the added weight will help in some capacity. Good luck.
    Old 03-17-2015, 03:08 AM   #13
    cswinings is currently offline
    My Model: z240
    My Engine: 7.4
    Send cswinings:
    When you go to pull out, have all your passengers hop into the bed of the truck, the extra weight will give you the traction you need. Also you can make sure you top off your tank before you get to the lake, fuel weighs about 8lb per gallon 35 gal = 280 extra lbs.
    Type of tow vehicle? m&mmariah Trailering and Tow Vehicles 0 07-27-2010 04:28 AM
    New Tow Vehicle ShabahZ280 Trailering and Tow Vehicles 11 10-20-2009 04:45 AM
    what are you towing??? mashymariah Watersports 6 02-07-2009 10:41 PM
    Great Tow vehicle for your Mariah! Z275 Other For Sale 0 09-26-2007 04:24 PM
    There are 318 users
