Winch & strap lb rating?
Trailering and Tow Vehicles
Old 07-15-2011, 01:57 AM   #1
dpriebe is currently offline
My Model: 2000 Z244 Jubilee
Send dpriebe:
Default Winch & strap lb rating?
I am starting to look around at replacing my winch and strap. I have an original Prestige trailer for my 2000 244 Jubilee. I am assuming that the current winch on my trailer is original. It indicates that it is rated for 2800 lbs. My boat weighs considerably more than that, 4,700 lbs dry. I know that the weight rating for the winch does not indicate that it can lift the actual boat. All it needs to do, is to pull it up on the trailer. Currently when I retrieve my boat, I hardly winch it up at all. Usually I am able to drive it right on. But when I do winch it, the winch and strap sounds like it is under considerable strain, so much so that I actually am afraid that it is going to break. And yes, I have replaced my strap a couple of times. So, do I need a bigger winch? Or should a 2800 lb winch be ok? I've done a good bit of googling for this already, and I have yet to find a boat weight to winch rating weight ratio.
Thanks, Dave
Dave Priebe
2000 Mariah Jubilee Z244
tow vehicle: 2005 Nissan Armada
    Motorized Boat Winch Douglas Alderman Chit Chat/Off-Topic 3 11-01-2009 01:28 AM
    Need Help Quick! Winch strap.... depman160 Trailering and Tow Vehicles 2 10-24-2009 12:02 AM
    Little spring in trailor winch lever... kevo Trailering and Tow Vehicles 2 07-28-2008 06:28 PM
    There are 354 users
