what truck to get
Trailering and Tow Vehicles
Old 02-09-2010, 04:03 PM   #11
apickens99 is currently offline
My Model: Z272 Shabah
My Engine: 502 Mag Bravo I
Send apickens99:
Default Re: what truck to get
This fall I bought a Z272 and pulled it home about 650 miles with my 2006 Chevy Silverado 1500HD equipped with the 6.0 engine. From what I can tell, my 1500HD is pretty much compariable to the 2500 except that it has a slightly different frame, rear end, and one less leaf spring. I had no troubles whatsoever making the pull home.
Good luck in your search!
  • Old 02-12-2010, 06:20 PM   #12
    95Z212's Avatar
    95Z212 is currently offline
    My Engine: 5.0LX Alpha 1
    Send 95Z212:
    I pull my Z-212 with an 09 GMC 2500HD V8 or a 08 Chevy Duramax with EFI Live tuner, and turbo back exhaust. I prefer the Duramax, theres something about pulling a boat outta the water with the truck whistling away The tow/haul mode on both of these trucks are very nice also, I rarely use the brakes stopping...I think the Yukons and Suburbans have the same thing...
    Jmkhiggs likes this.
    1995 Shabah Z212 V8
    2012 CRF 450R
    My location
    Old 02-15-2010, 01:23 AM   #13
    MariahMan's Avatar
    Status: Admin Guy
    My Model: 252 Shabah
    Gallery Images: 211
    Send MariahMan:
    Originally Posted by ShabahZ250 View Post
    I've always been impressed by the towing claims the of Toyota and Nissan, however MariahMan's the first actual real claim I've heard that's over 5000lbs!
    As a full disclaimer, my Titan is setup to tow much more than the off the lot version. I got beefy overload springs in the rear, a bigger diff cover for more cooling, larger sump for the transmission for more cooling, and load range E tires. We also use an equalizer hitch with 4 point sway control on the trailer.
    All that said, i don't think i'll tow 11k with the truck again. Not only was it illegal and i would have been screwed if we'd of had any sort of accident, but 28' of enclosed trailer on the relatively short wheelbase Titan made for some interesting movements when we encountered wind. Even just going by truckers was interesting. In my defense, we didn't know it was 11k until after we got back and weighed it. Should've checked before we left, that's for sure.
    I was EXTREMELY impressed with the truck though given that it held up to the abuse of that trailer over 7500 miles of towing and had plenty of power going up the passes. I would certainly have no concern towing a boat weighing 9,000lbs given what the truck has already towed successfully.
    I hope that helps!
    -Ryan
    ThunderShark Web Solutions
    Old 04-23-2010, 02:08 PM   #14
    7powerstroke3 is currently offline
    Send 7powerstroke3:
    If you want a truck that will tow a big boat, up hill, on cruise, and can hardly tell that you are towing anything at all, buy a diesel....a real truck. Preferably a Ford. But other diesels are fine too. (Cummins, Duramax)
    Old 04-23-2010, 02:21 PM   #15
    LJ's Sunset Dream is currently offline
    My Engine: 502ci, Bravo III
    Send LJ's Sunset Dream:
    Exactly,
    My F-250 with a 6.4 Turbo Diessel got me pulled over for speeding (up hill), pulling my Z252 Shabra
    Unfortunatly now that I have upgraded the boat to the Z280MCC I'm back drivinf an F-150 that won't pull it very far safley.
    Old 04-24-2010, 01:20 PM   #16
    Geez LJ's Sunset Dream, a Z280MCC and a F-150, you've got to be like right on the F-150's limit, yeouch
    Old 04-29-2010, 06:24 PM   #17
    Yup,
    luckily i keep her in a boat house,and have the use of a buddys Chev 2500 p/u if I want to take it to lake Erie or Ontario
    LJ
    Goes in the water today!!!!
    Truck rims on 1998 Chariot Trailer? dakotaman728 Trailering and Tow Vehicles 6 11-12-2009 01:25 AM
    There are 324 users
