Bimini placement when towing
Trailering and Tow Vehicles
Old 07-23-2021, 01:10 AM   #1
Campingshadow is currently offline
My Model: 198 SE Shabah
My Engine: 5.7 L Alpha One
Send Campingshadow:
Default Bimini placement when towing
My Bimini top will not lay flat on the back of the boat for towing. I do not want to have to reinstall on sides each time we tow. Really a pain for one person to do by themselves. Currently, I have it laying in front of the windshield. Does not look streamlined there but works. As you can see from the attached photos, the bars of The top will not clear the sides of the windows.. Is there some adjustment I need to make, or is it just meant to be in front of windshield…as it is, it works fine. I would like to have it along back seat as most boats do. Get so many compliments on this boat and want her to look her best!
The top has a good top cover. Just put the ties around it to keep it from bouncing on the road.
Shadow
1997 198 SE Shabah
  • Old 07-23-2021, 01:54 AM   #2
    GaryDoug's Avatar
    GaryDoug is currently offline
    My Model: Z202
    My Engine: 5.7L Bravo III
    Send GaryDoug:
    Default Re: Bimini placement when towing
    I have seen many different mounting locations on these boats. None of them really fit well when stowed. Mine is similar to yours and when the cover is on, I leave it forward as in your 2nd photo. Underway, I put it back, and have replaced the rear straps with solid tubes that attach to pivot mounts and quick release pins at the rear. That way it stays up and out of the way when not in use.
    Old 07-23-2021, 02:00 AM   #3
    Mine is mounted inside my side windows so it lays down fairly flat for towing.
    Old 07-23-2021, 03:44 PM   #4
    Send Campingshadow:
    Mikey, yours mounts inside the windows. My mounts are on the outside of them.
    Gary, did you add the pivot mounts? My boat does not have those. I have seen them on others as well.
    Shadow
    1997 198 SE Shabah
    Old 07-23-2021, 03:47 PM   #5
    GaryDoug's Avatar
    My Model: Z202
    Send GaryDoug:
    Yes I added them.
    Old 07-23-2021, 03:56 PM   #6
    Send Campingshadow:
    Smart man. Beyond my abilities, but a good solution.
    Shadow
    1997 198 SE Shabah
    Old 07-23-2021, 08:32 PM   #7
    jarwiebe's Avatar
    jarwiebe is currently offline
    My Model: Z210 Shabah
    My Engine: 5.7 LX Alpha I
    Gallery Images: 2
    Send jarwiebe:
    I mounted my Bimini mounting outside of the windscreen and outside of the snaps for the snap on cockpit cover so that the top can be snapped on without removing the Bimini.
    Cheers
    Jake
    1996 Z210 Shabah
    Mercruiser 5.7LX
    Alpha One Drive
    80 Lb. SX Smart Tabs
    SX19 GPS placement n36511 Sea Fox - Mariah Talk 4 03-27-2019 01:42 AM
    new speaker placement help phillycincykid Sea Fox - Mariah Talk 0 09-01-2015 12:54 AM
    Aluminum j-channel placement??? ghostryder Projects 3 04-18-2014 01:52 PM
    Boat Name Vinyl Placement lumbercitybravest Original Mariah Talk 23 02-04-2014 02:16 PM
    what are you towing??? mashymariah Watersports 6 02-07-2009 10:41 PM
    There are 264 users
