Leaf spring question
Trailering and Tow Vehicles
Old 09-18-2019, 09:51 PM   #1
Tlolesen's Avatar
Tlolesen is currently offline
My Model: 182
My Engine: 4.3 merc
Gallery Images: 3
Send Tlolesen:
Default Leaf spring question
Here's some pics of the springs on my trail rite trailer that came with my 2001 Shabah 182. Best I can read on the tag it says axil gross weight 3700 max trailer weight 3076. According to the 01 brochure boat weight 2720 I assume that's dry with a full 38 gal of fuel it's 2948. So I'm still under the trailer max. I'm no expert but the springs don't look right, they don't seem broken anywhere. Any comments or suggestions
  • Old 09-19-2019, 03:36 AM   #2
    Default Re: Leaf spring question
    Springs on that trailer look like they've been overloaded by the Mariah.
    Old 09-19-2019, 12:18 PM   #3
    Tlolesen's Avatar
    My Model: 182
    My Engine: 4.3 merc
    Gallery Images: 3
    Send Tlolesen:
    I'm in the process of buying part's to replace all the bearings and change over to disc brakes. I looked into getting a new one but will cost over 4 grand and don't think it would be any better built. Do you think i could replace the springs with something with a higher weight rating and keep this trailer?
    Old 09-19-2019, 02:12 PM   #4
    Replacing the springs with something stronger will likely result in additional weight which may push you even closer (or over) your trailer's limit. I would sell that trailer and buy one that fits.
    Old 09-19-2019, 02:46 PM   #5
    Tlolesen's Avatar
    My Model: 182
    My Engine: 4.3 merc
    Gallery Images: 3
    Send Tlolesen:
    Since my boat is an 01 I'm guessing the dealership just put it on whatever would work before they closed. It fits the boat perfect dimension wise. I'll start looking for a replacement, do you think I need a duel axil or should I stick with a single? Except with better suspension.
    Old 09-21-2019, 01:26 AM   #6
    Tlolesen's Avatar
    My Model: 182
    My Engine: 4.3 merc
    Gallery Images: 3
    Send Tlolesen:
    I have done some research and found this is an
    "Open Eye or C Hook" slipper spring. I took the photos to a trailer repair place and there saying the spring is around 20 year's old and is just fatigued which is not unusual for it's age. So looks like I will be changing these along with my bunks and disc brake upgrade this winter. Thankfully there relatively cheap.
    Spring Cleaning Shane.walker11 Original Mariah Talk 6 05-01-2014 08:34 PM
    Spring? mikeyt Chit Chat/Off-Topic 9 05-01-2014 05:20 AM
    Pre spring Joy Brian General Maintenance 3 03-20-2010 01:10 PM
    Spring Startup Help Corndog General Maintenance 7 02-18-2009 12:04 AM
    It's spring time ! 180diablo Chit Chat/Off-Topic 10 04-09-2008 09:16 PM
    There are 337 users
