Water in engine oil
Old 07-28-2021, 06:08 PM   #1
jamiefoz is currently offline
My Model: 183 Shabah
My Engine: Mercruiser 4.3 Alpha
Send jamiefoz:
Default Water in engine oil
I have a 4.3l mercruiser V6 and when I checked the engine oil a few weeks ago it was very creamy, so I drained it and was advised to change the intake manifold gaskets which I did and cleaned out the crack case as best I could. Having replaced the intake manifold gaskets, oil and oil filter I took it on a test run for a couple of hours and having checked back in the engine, the oil is back to the same creamy state it was in before. Is there anything else that could be causing it apart from head gaskets or a cracked block? I have done compression tests on each cylinder and they are all very similar so I find it hard to believe that it would be the head gaskets.
Thanks in advance,
Jamie.
  • Old 07-29-2021, 02:36 AM   #2
    Tlolesen's Avatar
    Tlolesen is currently offline
    My Model: 182
    My Engine: 4.3 merc
    Gallery Images: 3
    Send Tlolesen:
    Default Re: Water in engine oil
    I put a response in the Mercury thread
    Old 07-29-2021, 12:03 PM   #3
    Hudson River Steve's Avatar
    Hudson River Steve is currently offline
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    I would perform a leak down test on each cylinder. You either have a leaking head gasket a cracked block or heads.
    Sent from my SM-N975U using Tapatalk
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    4.3l v6 , mercruiser , oil , water in oil
    Water in engine oil jamiefoz Mercury MerCruiser 1 07-29-2021 02:27 AM
    What water temp does your engine run at? Jeff Barnett Mercury MerCruiser 15 05-13-2018 01:46 AM
    4.3 LX Water in oil jb57 Mercury MerCruiser 19 09-23-2013 12:35 AM
    how much water do you take on? bpfirrman General Maintenance 7 04-29-2008 09:35 PM
    Total Members: 18,525
    Total Threads: 12,958
    There are 244 users
