Inverter or on board charging system
Old 02-13-2020, 05:12 AM   #1
454mag is currently offline
My Model: Z220 Talari
My Engine: 454 Mag
Send 454mag:
Default Inverter or on board charging system
Can anybody tell me where the inverter is on a 2001 275 St? When I plug in the boat for shore power I'm not getting any charging to batteries. Not sure where look, or where to start in tracing back to battery charger or inverter. There is a switch inside cabin under driverside dash where control panel is but, that's all I can find. Thanks
  • Old 02-13-2020, 06:16 PM   #2
    Lancer is currently offline
    My Year: 2003
    My Model: Z 235 Devanti
    My Engine: 7.4 Bravo 1
    Send Lancer:
    Default Re: Inverter or on board charging system
    we have a 235z cc and when we plug into shore power it just energizes a 120 receptacle in the cuddy area if this helps
    Old 02-13-2020, 10:03 PM   #3
    My Engine: 454 Mag
    Send 454mag:
    I'm pretty sure there is a charging system because there is a switch in cuddy that says battery charger on/off. I just cant get any amperage to the battery cables to say they are charging when I have it plugged to shore power. I have 2 outlets down there that work as well as a microwave that works also but no charging power. If I could find out where the charger or the inverter is, that would be a starting point.
    Charging System Problem…... TCJ95Z-235 Introductions 3 08-02-2014 08:02 PM
    Power inverter Ntatro Projects 3 11-30-2013 06:48 PM
    Inverter Generators? JAlderman1 Original Mariah Talk 9 10-17-2013 07:23 PM
    Charging issue Twkenny Mercury MerCruiser 4 04-04-2011 12:56 PM
    Dual Pro Battery Charging System jasfiveo Original Mariah Talk 1 05-25-2010 09:40 PM
    Total Members: 18,527
    Total Threads: 12,958
    There are 140 users
