Fuse problem
Original Mariah Talk
Old 05-16-2009, 12:45 AM   #1
brucedennis1 is currently offline
Send brucedennis1:
Lightbulb Fuse problem
Fuse blew after i turned every thing on. Killed everything except trim so I was able to get it out of water. Started looking and this is what I found. A 20 amp fuse on the fuse block burned into. But now I am wondering why I lost everything. The fuse block was fed through the 20 amp fuse on the block itself. That didn't make sense to me. I did some more trouble shooting and found that the wire that is suppose to feed the fuse box was going to the ignition switch. So i dig some more and find that both these red wires go to a common plug with a black ground wire. The two reds were switched apparently from factory. Switch two wires proper way. don't know if anyone keeps blowing fuses or not but if so its worth checking.
  • Old 05-16-2009, 12:49 AM   #2
    dudders's Avatar
    dudders is currently offline
    My Year: 2006
    My Model: SX18
    My Engine: V6 4.3L
    Gallery Images: 53
    Send dudders:
    Default Re: Fuse problem
    what Model and year boat do you have Brucedennis1??
    My '06 SX18 had the oil pressure and water temp guages swapped around new from the factory!!
    Tony
    Perth, Western Australia
    Schizophrenia, together I can beat it.
    Old 05-16-2009, 12:58 AM   #3
    Send brucedennis1:
    Mine is a 1997 jubilee 21 ft.
    Old 07-03-2009, 02:37 AM   #4
    1999Mariah's Avatar
    1999Mariah is currently offline
    My Model: 1999 Shabah 182 Merc 3
    Send 1999Mariah:
    I was installing a new stereo, everything worked one second, the next all the buttons stopped working and only the trim worked. I check the fuses at the wheel and a 15 amp was blown, replaced it, still nothing worked, I also check all the fuses at the battery off switch... I have the wiring diagram, not doing me much good though, anyone have any ideas??
    Unplugged every single thing I could, found a loose power cable...!
    Old 07-04-2009, 01:56 AM   #5
    Send brucedennis1:
    Not sure but see if you have a circuit breaker at the engine. If that's ok I would make sure I didn't have another fuse block some where. I had two of them behind the shifter. With a volt meter I would check to see if I had 12 volts coming in to the fuse block. If not you will have to work your way backwards until you find the 12 volts. Is your lights or anything working? My way of thinking was a radio shouldn't kill things like you lights. That could be dangerous at night. Thats why I started looking deeper into my problem and finally found the real problem. Hope this helps some.
    Old 07-04-2009, 02:16 AM   #6
    1999Mariah's Avatar
    Send 1999Mariah:
    Yeah, I totally hear you...I would think there would be some kind of redundancy built into the electrical system.
    Bilge pump fuse location Jess Bembry Original Mariah Talk 4 06-26-2011 05:34 PM
    Fuse diagram thawk Original Mariah Talk 2 05-13-2009 02:54 AM
    Fuse Panel and Ground Bus locations and info? stereoman405 Original Mariah Talk 0 05-06-2009 04:13 PM
    Fuse Box ?? mariahman81 Boating 101 0 07-16-2008 04:20 PM
    Fuse Amp Size Douglas Alderman Boating 101 1 06-11-2008 06:04 AM
    Total Members: 18,994
    Total Threads: 13,326
    There are 339 users
