Wiring Diagram
Sea Fox - Mariah Talk
Old 04-10-2008, 08:46 PM   #11
bakdraft is currently offline
Send bakdraft:
Default Aha! more info.....
Finally I decided to just get in there and find out how to silence that battery sapping bilge pump!
First I lifted the dashboard to expose the circuit breaker. - see photo - I disconnected the spade connectors from the circuit breaker only to find the pump still kept running It seems the circuit breaker next to the bilge pump is only for the switch and not the auto function.... - keep hunting.
Then I investigated the inline fuse on the battery switch (right hand side) . - see photo - Removing the 5A Fuse on the Battery side of the switch did the trick
This stopped the auto pump running, BUT the switch on the dashboard would still work for manual operation.
However, as I do not want to take the fuse in and out all the time, I will have to fit an inline switch - but for now at least it is quite
Dave
  • Old 04-10-2008, 09:46 PM   #12
    dudders's Avatar
    dudders is currently offline
    My Year: 2006
    My Model: SX18
    My Engine: V6 4.3L
    Gallery Images: 53
    Send dudders:
    Awesome work Dave, I will pass this on to the other guys with the newer Mariahs.
    Thanks for all your work and sharing with us. Top stuff.
    Tony
    Perth, Western Australia
    Old 04-15-2008, 06:46 AM   #13
    MariahMan's Avatar
    Status: Admin Guy
    My Model: 252 Shabah
    Gallery Images: 211
    Send MariahMan:
    What it looks like here is Sea Fox - Mariah installed a cheapy bilge pump not equipped with a float switch. Rather than remove the fuse or install a toggle switch you have to worry about, i would install a float switch next to the bilge and use the circuit that the 5 amp fuse you removed was protecting. This way you still retain the automatic feature incase water does come in the bilge and don't have to worry about flipping a switch; it's completely automatic with no "searching" for water by coming on every 5 minutes.
    Here's an example of the switch i'm talking about:
    http://www.westmarine.com/webapp/wcs...5&classNum=304
    -Ryan
    ThunderShark Web Solutions
    Old 04-15-2008, 08:15 PM   #14
    Send bakdraft:
    Funnily enough... the float pump you listed is made by Rule... the same company that supplies the pain in the a** drain your battery pump. Rule advertise it as better than a float switch and it is advertised on the same website at nearly twice the price of the float switch.. but I would much rather have the float switch model!
    The problem with fitting it is that the current pump is exactly dead centre under the engine... absolutely impossible to reach...
    So I guess it will have to be a switch, bearing in mind that the dashboard always works... fuse or no fuse
    Dave
    Old 05-05-2008, 06:19 PM   #15
    dudders's Avatar
    My Year: 2006
    My Model: SX18
    My Engine: V6 4.3L
    Gallery Images: 53
    Send dudders:
    I asked the guys at SeaFox about this Bilge Pump system. Here is the reply and attached PDF's for the pumps.
    If you have any queries regarding the newer Mariahs, Stewart has always been very helpful. Just send him an email, I am sure he will help you out.
    Attached you will find the information you are looking for on our bilge pumps. Overall, I would say our response to the pump has been very positive. We made the change about two years ago because we noticed a lot of warranty claims for the replacement of float switches and bilge pumps. Our engineering department found that debris was clogging the float switch and shorting the switch and pumps. Since the change, the claims have been dramatically decreased and we have found the once boat owner's understand how the pump works, they are generally pleased. If the boat will be taken out of the water for an extended period of time you may want to consider removing the in-line fuse from the pump.
    Please let me know if I can be of further assistance.
    Stewart Mitchell
    Sales Manager
    Sea Fox & Mariah Boat Co.
    (843) 761-6090 x 23
    Tony
    Old 05-05-2008, 08:06 PM   #16
    Send bakdraft:
    Stewart Mitchell
    Sales Manager
    (843) 761-6090 x 23
    Hi Dudders,
    I have spoken to Stuart a couple of times... and he also sent me the same information which I had placed into the owners manual section. he also posted me an addtional leaflet that explains the 3 minute run on time. Additionally he sent me a wiring diagram... that was not much use, but I will add it to the manual section.
    What frustrates me is that the clear priority is to boats in a marina. If you boat is out of the water when not in use, the remove the fuse option is a real pain. It is awkward to reach, difficult to remove, easy to drop AND very easy to forget to put back in. The switch on the dashboard is a rocker - the backside of the rocker is not used, so maybe that would be a better solution. Failing this an illuminated inline switch by the fuse would have been an easier solution.
    I am sure their warranty claims maybe down, but my battery charge status is also down - not much good when the boat is stored where there is no nearby power.
    Old 05-06-2008, 03:18 AM   #17
    dudders's Avatar
    My Year: 2006
    My Model: SX18
    My Engine: V6 4.3L
    Gallery Images: 53
    Send dudders:
    Ah, didnt realise that you had already sorted this and posted it. Sorry for doubling up on the info, teach me for not reading the forum eh??
    I agree, it is a real pain, and yes directly focused on moored boats, there really must be a better option. I bet Jimmy Faulks wouldnt have let this go as it is....
    Tony
    Old 06-26-2009, 01:56 AM   #18
    Cliff_Haskins is currently offline
    Send Cliff_Haskins:
    Default Re: Wiring Diagram
    Couldn't help but reply to this one. Not sure of the model battery switch Sea Fox is using, but it is a matter of which terminal the power for "auto" is attached to. A typical Perko 2 battery switch would have a 1 2 and all, i believe (common, maybe, been awhile). Switching the ring terminal from the "battery" terminal to a "common" would kill power to the auto side when the battery switch is turned off. Understand, however, that the automatic feature of a bilge pump must be active from a manufacturer, due to obvious liability. RV manufacturers have faced the same dilema with voltage draw from 12 v CO Detectors (Was told they cycle every 90 sec. at a miniscule amperage). Anyway, somewhere in the fine print is where they will tell you that they are not responsible for water ingress due to a modification of the automatic system. Just my 2 cents.
    Wanted: Electrical Wire Diagram (99 Jubilee) 214 Douglas Alderman Mariah Parts For Sale & Wanted 3 04-13-2008 05:22 AM
    wiring schematic dieselwiezil Original Mariah Talk 1 04-07-2008 03:04 PM
    Need Wiring Schematic for 98 Z255 chadh Introductions 1 03-10-2008 03:30 PM
    Wiring quasipadro Original Mariah Talk 1 01-10-2008 08:08 PM
    mariah wiring 180diablo Original Mariah Talk 11 09-25-2007 12:24 AM
    There are 233 users
