Table Support?
Hi guys,
how are you doing ? we bought last year a Mariah SX25 here in Dubai. The only thing what was missing on the Boat was the Support for the Table. Our Dealer here.............forget about ! Who have an idea where we can find this part ? Looking forward hearing from you |
Re: Table Support?
Hi
il_Mio installed a Springfield table onto his SX18. Now I dont know if this will be the same size as yours, but it might be a good start. Click this link. http://www.mariahownersclub.com/foru...e-project.html Regards |
Re: Table Support?
thanks a lot for this idea ! Do you have an Idea where I can order this Table ? I tried to find a Table in the UAE but...............nothing ! Thanks and regards Michael |
Re: Table Support?
Re: Table Support?
Regards Michael |
Re: Table Support?
I found the Table on their site.........thanks a lot. Do you may remember the Installation depth of the Support ? |
Re: Table Support?
Looking at Johans installation, he cut a hole in the carpet then attached the base to his floor.
After the installation he reinserted the removable carpet. The top of the base looks to be about 100mm to 130mm above the level of the floor. Hard to tell exactly. The table base is 27" tall then the table top. The 6 stainless screws attaching it looked to be about 400mm long perhaps longer (hard to tell in the picture). He had to be careful because the fuel tank is under the floor. I hope this is enough info for you. He bought it from West Marine - table is Springfield. West Marine are one of our forum sponsors, so just click their link on the right. Cheers Tony |
Re: Table Support?
thanks a lot for the usefull informations. Ja.....it is a problem with the Fuel tank :-) Ok ....good idea ......of cause at this moment I will order it there :-) Cheers man Regards Michael |
Re: Table Support?
The support is indeed just placed on the floor (raises about 15mm), so does not require any holes except for the screws. Please pre drill the screw holes with a smaller drill bit without forcing so that you don't hit anything below ( example gas tank in my case). Once you have the pre drilled holes, you can probe with a nail or iron wire to see how deep you can go ( and hence what length of screws you can use). Always use stainless steel screws. Cheers, Johan |
Re: Table Support?
Too bad you are having such a harsh winter and unable to use your table, you so expertly installed mate. Come on Summer eh? |
| All times are GMT. The time now is 05:37 PM. |
