Removing the tachometer sc25
Sea Fox - Mariah Talk
Old 05-19-2025, 11:05 AM   #1
Sven is currently offline
My Year: 2006
My Model: sc25
My Engine: 5,0 MPI Bravo I
Send Sven:
Default Removing the tachometer sc25
Hello, I need some help. I own a 2006 sc25.
Since my tachometer is broken, I tried to remove it. The problem is that I can't remove it from the front.
I've loosened the screws on the silver cover that surrounds the instruments and tried to remove the entire instrument cluster from the front.
But that doesn't work.
From behind, below the dashboard, I can see two circular openings. However, they aren't big enough and aren't located directly behind the tachometer.
I can't reach the tachometer's mounting screws and cable connections from behind/below.
Does anyone have any idea how I can remove the tachometer?
Can I remove the entire dashboard?
I would be grateful for any advice. I don't want to force it and break anything.
Regards, Sven
  • Old 05-27-2025, 12:27 PM   #2
    GregT is currently offline
    My Model: Z275ST
    Gallery Images: 7
    Send GregT:
    Default Re: Removing the tachometer sc25
    Hi Sven, I'm not sure about the SC25 dashboard, but on my model 275 there is a bracket on the back of the tach holding it into the dash. I remove that bracket and the tach slides out the front. That would be tricky if you can't see the back of the tach on your model. You may try searching the forum on here for SC25 to see what comes up.
    I suggest you also post this question on the Mariah Owners Club Facebook page. Seems like most everyone has moved from this site to the facebook page so you will get more answers there.
    Propguard Mariah SC25, Bravo Three Fun Republik Sea Fox - Mariah Talk 0 04-26-2018 08:06 AM
    TOP Speed Mariah SC25 with 5.0L TomasSE Sea Fox - Mariah Talk 17 07-05-2015 01:44 PM
    Thinking of purchasing a 2008 sc25 with 425hp andrewbarber Sea Fox - Mariah Talk 3 11-09-2009 01:37 AM
    There are 427 users
