Looking for Speedo Pickup for 1999 Shabah 250
Old 08-15-2011, 10:10 PM   #1
sandon is currently offline
My Model: Z250
My Engine: 7.4 Bravo III
Send sandon:
Cool Looking for Speedo Pickup for 1999 Shabah 250
Can you find the original speedo pickup sensor on back of stern or do you just need to replace with a GPS unit
  • Old 08-16-2011, 12:04 AM   #2
    Default Re: Looking for Speedo Pickup for 1999 Shabah 250
    The speedo pickup sensor is in the outdrive. If your speedo isn't working, it's probably blocked. On your outdrive, down by the bottom fin, there is a small cut out indentation in the back (towards the boat). It tends to get clogged with debris every now and then, and just needs to be cleaned out with a nail, coat hanger, or a drill bit (not attached to drill!)
    The paddlewheel sensor that is located on the port side next to the outdrive is for the "Trip Computer", (like an odometer). It's the small black rectangular analog gauge on the dash.
    Old 08-16-2011, 01:17 AM   #3
    My Model: Z250
    Send sandon:
    Thank you. I just assumed the trip pickup was the speedo like the old school kind you normally see. The trip odometer does not work either because the wheel is gone but the bracket is there. I will look for the hole on the outdrive and hope that's the easy fix. Can you still get the paddle wheel replacement for the trip odometer. I just purchased this boat and wanted to make sure everything works.
    I see you have the same boat. Ever have a trim issue for trim up at the captains seat controls. Rear trim switch and trailer switch work fine so I am assuming its the switch in the throttle?
    Thank you for the help
    New Guy, 1999 182 Shabah KStone803 Original Mariah Talk 2 05-01-2010 03:52 PM
    How to Load a Bayliner into a Pickup 101. z275st Chit Chat/Off-Topic 5 01-12-2009 01:29 PM
    Should I Buy 1999 202 Shabah??? george strapko Introductions 4 07-21-2008 09:00 PM
    1999 shabah 202 owner chriscarxman Introductions 3 10-15-2007 12:05 PM
    Total Members: 18,994
    Total Threads: 13,326
    There are 400 users
