Naylor Boat Lift
Old 01-18-2011, 01:15 PM   #1
Y-Knot's Avatar
Y-Knot is currently offline
My Model: 2009 FS-18 4.3 Mercruiser Alpha I
Send Y-Knot:
Default Naylor Boat Lift
Hey all,
I recently purchased a previously enjoyed Naylor vertical lift for my FS18. When I looked at the unit, I was assured the lift capacity was "around 3,600#".
Knowing the FS18 weighs in at 2,950 ish dry, I figured this would be adequate, albeit tight.
Well, most have probably guessed where this is going. It turns out the lift is rated to 3,000# max. I verified this with the manufacturer. yah........shudda done that first.
Has anyone been in or continues to be in this situation, that is, using a lift that is this close to the boat weight? Any idea where the fail point is?
I'm a structural tech guy and can tell you right now it's not the 5/16 ss cables. Might be the winch or the actual member size that fails (if it does).
Any thoughts on this? No doom sayers please.....I'm worried enough about it already.
Cheers,
Y
2009 FS-18, 4.3 Alpha 1
  • Old 01-22-2011, 05:24 PM   #2
    indykoch's Avatar
    indykoch is currently offline
    Send indykoch:
    Default Re: Naylor Boat Lift
    The weakest points I've heard/seen on lifts are usually the cables and the cross members mounting the bunks or bunks themselves. Remember, the ratings are when new, not after a number of years exposed to the weather and environment.
    I don't want to be a "doom sayer", but you really are asking for trouble. I guess if need be - try keeping the weight as low as possible (fuel, people, gear, cooler of beer, etc.) while on the lift. I'm sure there's a safety factor in there as well. Good luck, and I'll keep my fingers crossed about not seeing your next post on here asking how to repair or dry out your boat that fell into the water!
    Ryan
    Previously - '99 Z212 Shabah
    350 Mag MPI
    Old 01-23-2011, 05:46 AM   #3
    warner0308's Avatar
    warner0308 is currently offline
    My Model: z280
    My Engine: 454
    Send warner0308:
    aw dont be scared,i got a 7900lbs dry on a 7000lbs lift. just make shure your ins. is paid up to date!lol
    Seat lift mechanism? anthonybradley Original Mariah Talk 14 06-19-2017 10:09 AM
    hatch lift motor slade watson Introductions 6 06-10-2014 03:55 AM
    Sunstream Sun Lift hammy44 Trailering and Tow Vehicles 0 07-23-2010 07:24 PM
    6000lb Sunstream Sun Lift hammy44 Trailering and Tow Vehicles 4 03-05-2010 12:46 AM
    Sun pad lift moving very slooooowww...... launchpad Original Mariah Talk 1 04-21-2009 11:26 PM
    There are 254 users
