Fuel Drain
Old 08-30-2009, 02:17 AM   #1
brian9120 is currently offline
My Model: 1998 Z302 Merc 502
Send brian9120:
Default Fuel Drain
Is there a fuel drain on a 1998 302?
  • Old 08-30-2009, 04:44 AM   #2
    Default Re: Fuel Drain
    Hi brian9120,
    If you are referring to the fuel tank, there isn't a "drain" plug per se. To empty the remaining fuel, you can try pumping it out through the fuel pickup tube to the motor, or through the main tank filler hose or you can access the sender unit (there is an access panel just in front of the motor), remove the sender and drain any remaining fuel from there.
    Good luck,
    Floor Drain Problem Douglas Alderman Original Mariah Talk 8 07-13-2010 01:45 PM
    Oil Drain Kit 272man Mercury MerCruiser 2 05-22-2009 12:33 PM
    Ski well drain/bilge drain jhaag41 General Maintenance 1 07-17-2008 10:09 PM
    Rear Seat Compartment drain boarder1010 Original Mariah Talk 9 06-09-2008 04:19 AM
    Wanted: Drain Sink Strainer Douglas Alderman Mariah Parts For Sale & Wanted 0 04-29-2008 03:50 AM
    Total Members: 18,995
    Total Threads: 13,326
    There are 393 users
