Transom mounted paddlewheel assembly
Old 10-31-2008, 09:55 PM   #1
Default Transom mounted paddlewheel assembly
Hi everyone,
I am looking for the transom mounted paddlewheel assembly that I believe is for the trip odometer and water temp. Any leads would be greatly appreciated!
  • Old 11-01-2008, 01:04 PM   #2
    OK WetWilly, I'm not 100% sure on this, but I believe it could be made by Lowrance. I've seen quite a few things on their site about paddlewheel sensors that read temp and speed. If you go to http://www.lowrance.com
    and click Products -> Accessories, and use the dropdown box for "Speed & Temperature Sensors" it'll give you some model numbers. Check yours and see if any of them match. I believe Mariah could have used their sensors, and just spliced the ends into the trip odometer and temp readout.
    Once I get mine back from winterization, I'll take a close look at mine and see what I can figure out!
    Old 11-03-2008, 02:35 AM   #3
    AirNavy's Avatar
    AirNavy is currently offline
    My Model: Z215 Talari
    My Engine: 5.7L Alpha One
    Send AirNavy:
    The 96 Z215 I'm about to buy has one on it, but I'm not sure what it is connected to. If nothing else I can probably get a part number off it this week while I'm tracing the wiring back to see if it is even hooked up to anything...
    Mickey
    AEC (AW) U.S. Navy
    Old 03-12-2009, 10:56 PM   #4
    AirNavy's Avatar
    Send AirNavy:
    Default Re: Transom mounted paddlewheel assembly
    Okay so I didn't get it that week, but what's 4 months in the big scheme of things? The one I took off of my boat is made by Airmar and the part number on it is 31-602-6-01. Unfortunately that number doesn't cross to anything on Airmar's site: http://www.airmartechnology.com . The closest ones I see are the S63 and ST63, but those aren't an exact match. Mine has a 5 male pin plug on the end of about a 4' cord.
    Mickey
    AEC (AW) U.S. Navy
    Old 03-13-2009, 08:36 AM   #5
    Hi AirNavy,
    Well you know what they say:"better late than never"!
    I really appreciate the info , I'll try and contact Airmar and see what I can do.
    Thanks again,
    Soot on transom area. z275st Original Mariah Talk 21 06-29-2008 04:09 PM
    Power deck lid Assembly?? '93 Shabah 212Z Rick Original Mariah Talk 6 03-31-2008 05:26 PM
    Transom shower on my Z255 Jeff Barnett Original Mariah Talk 1 09-06-2007 06:37 AM
    Transom shower moondance100 Original Mariah Talk 4 09-06-2007 06:29 AM
    Total Members: 18,994
    Total Threads: 13,326
    There are 323 users
