PROP Suggestion 98 Z202
Prop Talk
Old 07-05-2012, 05:20 PM   #1
jsburkey21 is currently offline
My Model: Z202
My Engine: 5.7 Alpha 1
Send jsburkey21:
Default PROP Suggestion 98 Z202
I have a 1998 Z202 with the carb 5.7. Currently i have a 21 pitch SS vengence prop on it, and it will hit 58-60mph. My RPMs read 4000. This seems a little low, but my question is if i get a 19 pitch (need better hole shot for wakeboarding) how bad will my top end suffer? Is this low of an RPM normal with this prop, motor, boat combo? Could my Tach be bad??
  • Old 07-05-2012, 06:22 PM   #2
    Default Re: PROP Suggestion 98 Z202
    First off i'm gonna suggest that you read the 'Sticky' at the top of this forum. It will give you the basics on props/pitch/WOT rpms etc and should answer all of your questions.
    Are you sure about that 60mph? Is that GPS or via your speedo? As for the tach, there is a small dial on the back of it marked 4 - 6 - 8 cyl. Give the dial a few spins & then reset it at 8 cyl. Sometimes a little bit of corrosion affects their operation.
    Old 07-05-2012, 09:00 PM   #3
    My Model: Z202
    Send jsburkey21:
    Thank you for the answers! They really helped out. Ill try the tach thing, and my speed was calculated on my speedometer not GPS. I have been looking and can't find a "CUPPED" prop like the one on the sticky. Ill take the boat out again this weekend with a GPS and make sure my tach is reading correctly.
    Old 07-09-2012, 12:07 PM   #4
    My Model: Z202
    Send jsburkey21:
    Does anyone else have a z202 that can share their prop size, pitch, speed, and rpms?
    Old 07-10-2012, 12:39 PM   #5
    DCB_MINDED's Avatar
    My Model: Shabah 238
    My Engine: 5.7 Alpha1
    Send DCB_MINDED:
    That RPM sounds a little low to me, but your outdrive gearing could be different.... I know 238 (with the 5.7) had a 3 blade 19" on it when I bought it and it was turning 4100 at 41MPH, but it was a dog out of the hole. I dropped to a 17" highfive for better holeshot and it runs 4450 at 39MPH.
    P.S. 58-60 sounds pretty high to me, the speedos on these things were not accurate at all. Try to get a GPS speed
    '99 Mariah Shabah 238
    5.7 Thunderbolt w/Alpha1
    Old 07-10-2012, 10:06 PM   #6
    mikesnowman's Avatar
    mikesnowman is currently offline
    My Year: 97
    My Model: 272 Shabah
    My Engine: 7.4 mag
    Send mikesnowman:
    i had a 96 Z200 5.7 alpha, 2 barrel carb. I had a 19 pitch rapture SS and it would spin about 4800 at 50 mph GPS. I tried everything to get more top end. Could not do it. I personally think the 21 is too much for that motor as I tired several and the rpm's came way way down in the low 4's. I was happy with the 19 for pulling and it would do 50 all day long fully loaded. I was going to go with a 4 blade 20, but traded for a big block. Good luck!
    Old 07-10-2012, 10:44 PM   #7
    The 19" pitch prop is pretty much standard for most of our Alpha One / Brave One applications so that would be a good place to start.
    prop suggestion 1994 davanti 454 mag bornmud Prop Talk 1 06-20-2012 12:29 AM
    Re: Prop - Z202 Lake Cruiser Prop Talk 0 06-12-2012 05:36 PM
    Z202 Shabah bbottino Introductions 1 09-13-2011 11:45 PM
    202 or Z202 sonnyduty Original Mariah Talk 8 09-01-2010 03:01 PM
    looking for prop size shabah z202 5.0 scottmori Prop Talk 6 05-29-2009 03:57 AM
    There are 353 users
