looking for prop size shabah z202 5.0
Prop Talk
Old 05-17-2009, 11:17 PM   #1
scottmori is currently offline
My Model: 1998 z202 shaba 5.0 alpha
Send scottmori:
Default looking for prop size shabah z202 5.0
hi i just bought a 1998 z202 with a 5.0/alpha i believe its 220hp? any way it has a stilleto stainless prop no pitch labeled on it? i am thinking the boat probably needs a 21p? any info appreciated i have had it out once but it was pretty rough so i couldn't get a good wot run.
scott
  • Old 05-18-2009, 02:48 AM   #2
    Default Re: looking for prop size shabah z202 5.0
    Hi Scott
    You get the same answer that i gave to gjaxon in the thread directly below yours since you have the same boat & motor combo......
    "Probably 14.5"dia x 19" or 14.25 x 21" pitch depending on what the boat was mostly used for. The 19 will give a little more low/mid range grunt while the 21 will give a slightly higher top end."
    The Stiletto is a good prop. If you take the prop off you should find the diameter/pitch stamped on the backside of the hub. Your engine has a recommended range of 4400-4800 rpms at WOT so ideally that's where you want to be.
    Old 05-18-2009, 01:15 PM   #3
    s.a.charlie's Avatar
    s.a.charlie is currently offline
    My Model: 93 talari"z" 19 5.0 mercruser alpha 1gen2 54mph so far
    Send s.a.charlie:
    I have a quicksilver mirage 19P good bottom range 54 mph top end @4800-4900 rpm
    Old 05-19-2009, 12:55 AM   #4
    indykoch's Avatar
    indykoch is currently offline
    Send indykoch:
    Yeah, I think a 21P would be a bit too much prop for that set-up. A good SS 19P would put you right at the rev limit and provide good hole shot, as s.a.charlie states.
    Ryan
    Previously - '99 Z212 Shabah
    350 Mag MPI
    Old 05-19-2009, 01:07 AM   #5
    Send scottmori:
    thanks for the reply's i will try a 19p
    scott
    Old 05-25-2009, 11:00 PM   #6
    Send s.a.charlie:
    scotty let us know how it works out for you ok
    Old 05-29-2009, 03:57 AM   #7
    Kitto's Avatar
    Kitto is currently offline
    My Model: 2002 Diablo 200 5.0L Merc. Alpha 1
    Gallery Images: 7
    Send Kitto:
    I've got the 5.0L as well with an 18 pitch Solas prop. I'm not impressed. I get maybe 4400 to 4500 rpms and not a very good holeshot. The problem I'm thinking I have is the elevation. The lake I've been at is around 5,000ft. so I'm sure that is sucking some horses. I'm thinking of a 17 pitch Stainless. Any recomendations as far as makes of props? I'm thinking the Quicksilver at this point as I don't want to break the bank. Craig
    Kitto
    2002 Diablo 200 5.0L Alpha 1
    1995 Z202 Shabah - Glad to be a part! rjobe Introductions 7 07-18-2010 02:13 PM
    prop size keith tindling Prop Talk 2 07-03-2009 03:33 AM
    Newby considering 1996 Shabah Z202 grommett Original Mariah Talk 7 09-06-2008 10:44 AM
    PROP Size? TALLRAM Prop Talk 4 07-28-2008 05:07 PM
    1996 Z202 Shabah 5.7 (ebay) 180diablo Mariah Boats For Sale & Wanted 0 06-27-2008 06:25 PM
    There are 257 users
