Help Please!!!!
Prop Talk
Old 06-26-2012, 06:00 PM   #1
PearcyPorker is currently offline
My Year: 2007
My Model: sx19
My Engine: 5.0
Send PearcyPorker:
Default Help Please!!!!
I am a newbbie here, but I have read through a lot of the post. I just recently bought a 2007 SX19 with a 5.0l and a 3 blade 14.5x19p aluminum prop. This past weekend was the first time I have had it on the water. When taking off the prop doesnt seem to get any bite and the RPM's rev way high. When on a plain it's turning 4,000 rpm's and running bout 28MPH, and that was only about half throttle. I never did try WOT because of the high RPM's. I did run it around 5500 for just a second then backed off quick. My questions is, what prop do you guys think I should look for and does anyone know close to what WOT rpm's should be. Thank you for the time and help.
  • Old 06-26-2012, 09:08 PM   #2
    Default Re: Help Please!!!!
    You have the right pitch prop for your boat/motor but what you likely also have is a spun prop hub which needs to be repaired or replaced before you do some damage. Find a local prop shop & have them check it for you.
    PearcyPorker (06-26-2012)
    Old 06-26-2012, 09:24 PM   #3
    My Year: 2007
    My Model: sx19
    My Engine: 5.0
    Send PearcyPorker:
    Mikeyt, Thank you sir for the info. I have been reading in another post somewhere, maybe another board about this. Is this something I can fix myself by pulling the prop and replacing the hub???
    Old 06-27-2012, 01:36 AM   #4
    Depends what kind of a prop hub you have. If its a press fit then no not likely. If its an interchangeable style hub kit then its fairly simple.
    Old 06-27-2012, 02:30 AM   #5
    My Year: 2007
    My Model: sx19
    My Engine: 5.0
    Send PearcyPorker:
    Thanks again Mikey!!!!! I pulled it off this afternoon and I'm going to take it to a prop shop tomorrow. I really do appriciate the help. This board is fantastic!!!!!
    Old 06-28-2012, 04:58 PM   #6
    My Year: 2007
    My Model: sx19
    My Engine: 5.0
    Send PearcyPorker:
    Update, took the Prop to a "prop shop" and everything looks good on the prop. I put it back on and checked the back of the Tach and it was set to 6 cyl., so I am going to take it back out this weekend and see if it was just in my head. I have also read a bunch of happy people on here that are using the "Smart Tabs". I have pretty much convinced myself to get these from everything I have read about them. Thanks again for the help!
    Old 06-28-2012, 06:19 PM   #7
    Glad to hear there was no problem with the prop. Give the small dial on the back of the tach a spin a few times then reset it at "6 cyl". Sometimes a little bit of corrosion (damp atmosphere in a boat) causes problems with the tach.
    Old 06-28-2012, 08:35 PM   #8
    My Year: 2007
    My Model: sx19
    My Engine: 5.0
    Send PearcyPorker:
    Actually, I messed up on my last post. My tach was set to 6Cyl. and should have been on 8Cyl. I have a 5.0L in my SX19.
    Old 06-28-2012, 11:53 PM   #9
    I should have caught that error too....
    That would explain the incorrect reading on the tach.
    There are 317 users
