Will this prop fit.. and is it a good one?
Prop Talk
Old 07-14-2010, 09:09 PM   #11
Default Re: Will this prop fit.. and is it a good one?
Originally Posted by Eick View Post
ive got a 4.3L in a 1997 shaba and im rilly spinnen cicles on a prop it came with a 14x19 prop but rpms are runnen 4800 at 35mils per hour .im whanting top end and cant go full throttle. was woundering if maybe going a 22 or 23 might be a choice.
Lets see if i can decipher this post. If you are only hitting 35mph at 4800 rpm then you have a problem. You should easily hit 46-48mph with the 19" prop. Is the prop damaged? Is the hub in good repair & not slipping? I have a '96 with the same motor & originally had a 21" on it. It gave me 50mph top end but was terrible out of the hole, particularly with a wake-boarder in tow. Going to a 22" or 23" will likely make that situation worse on your boat.
  • Old 09-04-2010, 04:55 AM   #12
    al levy is currently offline
    My Model: 272 shabah
    My Engine: 7.4 bravo 111
    Send al levy:
    stilletto may have to much rake for your boat. when repairing your prop make sure the diameter stays the same. go 4 blade and enjoy all around boating.
    Is this a good tune-up CARL SWINDLE General Maintenance 1 05-19-2010 02:35 PM
    good deal or not so good? wssb11 Mariah Boats For Sale & Wanted 6 01-06-2009 01:00 AM
    Good job! sledge437 Introductions 0 07-17-2007 07:04 PM
    Good work! kerry Introductions 2 07-16-2007 05:18 PM
    There are 245 users
