going ahead with a restorion.
Projects
Old 08-17-2011, 02:19 AM   #1
buchshot12000's Avatar
buchshot12000 is currently offline
My Model: z220 Talari
My Engine: 5.7L outdrive pending
Send buchshot12000:
Default going ahead with a restorion.
I have decided instead of doing just a fix-it and run it. i am going to attempt a proper Restoration. I still haven found interior colors, but I will try to color match it from parts not exposed to the sun. I thought the interior would match the exterior colors, but that's not the case, unless the sun caused that much change in colors.
  • Old 08-17-2011, 05:53 PM   #2
    Default Re: going ahead with a restorion.
    Awesome! Good luck with it, and keep us updated with the progress. If you've got any questions, just ask and we'll try and help you through it all!
    Old 08-19-2011, 01:35 PM   #3
    Send buchshot12000:
    Old 03-09-2012, 02:10 AM   #4
    Send buchshot12000:
    bringing up an post, but the restortion is back on, motor is in the machine shop, out drive is getting tested.
    I have a ? though. how to pull the interior out. and do you have to seperate the hull to replace carpet.
    Old 03-09-2012, 08:07 PM   #5
    DCB_MINDED's Avatar
    My Model: Shabah 238
    My Engine: 5.7 Alpha1
    Send DCB_MINDED:
    It's been my experience that boat manufacturers can get pretty tricky when it comes to hiding screws. The little "buttons" (if you have any) that are about 1" around will pop right off and there is a screw under them. Check in compartments, cubbies, and most of all..... BE PATIENT! if it isn't coming, then something is still holding. I havent seen too many clips that will just pull off. Mostly screws/bolts. Good luck! You are taking on a BIG job!
    Old 03-15-2012, 12:24 PM   #6
    Send buchshot12000:
    I got most of the interior out. and all the bad carpet. I dont really want to take the top off.
    It does look like some one has been in there before to get to the fuel tank. the deck looks like it was cut. and not glassed over when the put it back so its drying out now.
    There are 212 users
