Whistling Noise 98 Shabah Z242
Old 10-27-2014, 11:56 PM   #1
SoonerFan is currently offline
My Model: Shabah 242
My Engine: 5.7 Bravo III
Send SoonerFan:
Default Whistling Noise 98 Shabah Z242
Recently noticed a noise similar to the sound the alert makes when you first turn the key on prior to engaging the starter. There is now a sound very much like that when the boat is running. Any ideas? Thanks in advance.
  • Old 10-28-2014, 12:50 AM   #2
    msmith68's Avatar
    msmith68 is currently offline
    My Model: Z210 Shabah
    My Engine: 5.7 Alpah one
    Gallery Images: 2
    Send msmith68:
    Default Re: Whistling Noise 98 Shabah Z242
    Maybe low oil alarm?
    Old 10-28-2014, 02:15 AM   #3
    Send SoonerFan:
    Wasn't aware there was alarm for that, but I will definitely check that out. Thanks!
    Old 10-28-2014, 12:42 PM   #4
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    Just to clarify, that's low drive oil...not engine oil level.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 10-28-2014, 10:26 PM   #5
    Send SoonerFan:
    As in lower unit oil?
    Old 10-28-2014, 11:09 PM   #6
    My Model: Z280
    Yes, outdrive oil.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 10-29-2014, 04:44 PM   #7
    The warning system monitors 3 things.
    -gear lube level for outdrive
    -engine temperature
    -engine oil
    Check the gear lube reservoir on your engine. It's likely the culprit. If it's full and you're still getting the alarm, you may need to replace the gear lube reservoir sensor. It's a one piece deal that includes both the reservoir and sensor, and it's about $50.
    Check your engine oil level. Add as necessary.
    Watch your temperature gauge. If you're rising above 160 then you should replace your impeller before using it again.
    woodward33 likes this.
    Old 10-31-2014, 01:13 AM   #8
    Send SoonerFan:
    Thanks to all for your advice I'll report back on my findings.
    Old 11-11-2014, 12:02 AM   #9
    Send SoonerFan:
    Had my boat winterized this week and it was low on oil in the outdrive reservoir. Thanks for the feedback/good advice!
    $365 for winterizing seems pretty pricey for oil/filter change, changed outdrive fluid, fogged motor, and stabil. Cold weather coming in tonight, and they did pick it up from dry storage, service it, and return. More expensive every year.
    Old 11-11-2014, 02:43 PM   #10
    Wow, $365 for a basic winterizing service that doesn't even include outdrive removal, check, and lube? Man, that's steep. You can do it yourself and save quite a bit. It's actually a lot easier than most people think; I've been doing mine for the last 4 years. I think I spend about $150 for everything, and that's including winterizing water system, toilet, air conditioning, and generator. That takes about 3 hours to do everything, but you can probably get yours done in an hour or so!
    Initially there's a little expense to buy the winterizing kit, ear muffs, oil changer, outdrive oil pump, etc, but those are all one-time expenses, and still with all the supplies, you'll be under $365. But the biggest expense isn't monetary, it's trust in yourself that you can do it. That takes a pretty good amount of time to build that up. If you use the right stuff and follow the correct procedure every time, you'll never have anything to worry about, and it'll save you a lot!
    1998 z242 shabah Shabahz242 Original Mariah Talk 3 07-27-2019 12:15 PM
    1997 Z242 Shabah for sale in Iowa LOTO Z240 Talari Mariah Boats For Sale & Wanted 0 08-18-2014 03:52 PM
    98 Mariah Z242 Shabah For Sale rrobinson Mariah Boats For Sale & Wanted 0 06-17-2013 07:55 PM
    '97 Mariah Z242 Shabah jmitv Mariah Boats For Sale & Wanted 2 11-01-2010 01:50 PM
    Advise on a Shabah Z242 22empire Original Mariah Talk 4 02-22-2010 03:40 AM
    There are 381 users
