Advise on a Shabah Z242
Old 02-21-2010, 03:23 AM   #1
22empire is currently offline
My Model: 2000 Shabah 183 4.3L Alpha
Send 22empire:
Default Advise on a Shabah Z242
Currently I have a Mariah 183C.. I am looking at a Mariah Z242.. It has the 350MAG merc and a Bravo 2. Does anyone have experience with this boat? I am moving to a larger body of water. Georgian Bay actually. And I am wondering if this boat makes a good Bay Boat or not. The 183 is great but it is a little small for this body of water. Any advise or observations would be much appreciated. The boat is listed for $15k.. Is this reasonable? Thanks in advance folks...
  • Old 02-21-2010, 01:30 PM   #2
    MAJIC is currently offline
    My Model: 1997 Z252 Shabah
    Gallery Images: 9
    Send MAJIC:
    Default Re: Advise on a Shabah Z242
    i moved up from a 19' Monterey to our Z252 Shabah on Lake Winnipesaukee in NH. What a world of difference. The lake on the right winds will get 3'-5' chop. The Mariah handles it no problem. My only complaint is that the nose dips rather then staying high so waves do occassionally come over the top.
    I have a 7.4L, B3. Great motor. No problem moving the boat. Stong boats! Well built!
    MAJIC - Z252
    Old 02-21-2010, 05:09 PM   #3
    Send 22empire:
    I have notice the same thing with the Mariah hull design. The nose like to dip as the power and speed come up.. Great without real chop but A little worrisome if you have people in the front an a wave comes over.. I am still thinking it is a great boat. I just wanted some others opinions.. Thanks..
    Old 02-22-2010, 01:58 AM   #4
    Gallery Images: 9
    Send MAJIC:
    It's not that the nose dips - it's that the bow is designed with tip pointing down just a bit rather then continue straight up. This slight bow dip (Mariah hulls are not the only ones to do this) can increase the likelihood that water (chop and waves) can come over the top rather then being knocked down. In a 3-5' chop, you have to slow down a bit anyway, unless you've got a staunch back and no one in the bow... Adding trim tabs will help tremendously, if it doesn't already have them.
    They're on my list of to do's.
    MAJIC - Z252
    Old 02-22-2010, 03:40 AM   #5
    LHC Kirby is currently offline
    My Model: 2001 245
    My Engine: 5.? Volvo Penta
    Send LHC Kirby:
    I have trim tabs, and Lake Havasu AZ..... 3-5 with wind - only happened once, I try and get off when I see a system coming in. BUT, the boat was great, bad timing gave one small part of the wave over the top of the bow, but no problem that is what you have bilge pump for
    '97 Mariah Z242 Shabah jmitv Mariah Boats For Sale & Wanted 2 11-01-2010 01:50 PM
    need advise on buying 2001 Mariah urim Original Mariah Talk 7 04-23-2009 09:07 AM
    advise on boat buy urim Original Mariah Talk 4 04-22-2009 04:33 PM
    There are 368 users
