Trim Trouble
Old 06-19-2014, 09:56 AM   #1
Motorcyclesmack's Avatar
Motorcyclesmack is currently offline
My Model: Z250 Shabah
My Engine: 7.4L Alpha 1
Send Motorcyclesmack:
Default Trim Trouble
99 250z cuddy lower unit sometimes won't trim up when at idle speed and once as I was motoring down lake hit trim up and it wouldn't stop went all the way to trailer position. Down seems fine and seems to work all but one time at cruise speed. Trim switch on swim deck seems to be acting normal. Could it need a new switch on console or is it the trim pump itself acting up.
  • Old 06-19-2014, 01:27 PM   #2
    Default Re: Trim Trouble
    Read this STICKY on troubleshooting your trim/tilt system. It's simple to follow and will diagnose the problem quickly.
    Old 06-20-2014, 03:26 PM   #3
    Sounds like I finicky switch but the trouble shoot guide Mikey posted should get you an answer. Good luck!
    Trouble Shooting your Power Trim & Tilt Motor System mikeyt General Maintenance 0 07-03-2012 10:58 PM
    electric trouble flt1vfs Chit Chat/Off-Topic 3 06-26-2011 01:55 PM
    Ran into some trouble Mike S Original Mariah Talk 14 05-26-2009 06:05 PM
    Trim trouble shilo Sea Fox - Mariah Talk 5 02-20-2008 02:24 PM
    trim trouble aquaknot Original Mariah Talk 5 08-13-2007 12:17 PM
    There are 264 users
