electric trouble
Chit Chat/Off-Topic
Old 06-25-2011, 10:44 PM   #1
flt1vfs is currently offline
Send flt1vfs:
Default electric trouble
i am working onmy boat attatching the battery cables. There are the two large ones to start the engine and two smaller ones. Attaching the cables one way, the power trim does not work, but all the electica gauges work. Swapping them, the trim works and the gauges do not.
also the horn that sounds when you start the boat will not quit, so it cut it out. will this affect anything.
thanks
  • Old 06-25-2011, 11:20 PM   #2
    csterner's Avatar
    csterner is currently offline
    My Model: Z275ST Shabah
    My Engine: 6.2L Bravo III
    Gallery Images: 9
    Send csterner:
    Default Re: electric trouble
    Do you have 2 batteries or just one?
    Did you say that you cut your horn out?
    2001 Shabah Z275 ST
    6.2L Merc with Bravo III
    Old 06-26-2011, 05:21 AM   #3
    Zackattack's Avatar
    My Engine: 5.7 Alpha 1
    Send Zackattack:
    Im confused
    Zack
    1994 Z212 Shabah
    Old 06-26-2011, 01:55 PM   #4
    SEMIJim's Avatar
    SEMIJim is currently offline
    My Model: 182 Barchetta
    Send SEMIJim:
    Guessing where wires go is a good way to destroy things--and even start fires. If you don't know how to figure out how to connect the cables to your battery, find someone to show you.
    The wires should be colour-coded. Red goes on POSitive (+), black on NEGative (-). Other ways to tell: The large red wire will go straight to the starter solenoid, the large black wire straight to a ground point on the engine block, and the smaller red wire should have an in-line fuse holder.
    If things don't seem to match the above, as I said: Find somebody who knows something about these things to figure it out and show you.
    Once you get the battery hooked up properly, then start trouble-shooting why what doesn't work doesn't work.
    I believe you mean the alarm "buzzer." Yeah: It will affect your knowing when your engine or outdrive are in distress, perhaps resulting in very expensive repairs.
    When you say "won't quit," do you mean after you've started the engine, or if you turn on the key without starting the engine? If the former: You either have a problem with your engine or drive system or a bad sensor. If the latter: That's normal. It happens because one of the things alarmed is oil pressure. No oil pressure is regarded as a Very Bad Thing, so the alarm sounds.
    That alarm is on low oil pressure, engine over-temperature, and low drive fluid. If the alarm is sounding after the engine's running, you need to find out which it is and whether a bad condition exists or the sensor is lying.
    DO NOT leave that alarm disconnected. Many's the user here who's engine's been saved by that alarm when something suddenly went amiss.
    thanks
    You're welcome.
    Jim
    “The bitterness of poor quality is remembered long after the sweetness of low price has faded from memory.” - Aldo Gucci
    Click Here --> Help Support The Mariah Owner's Club <-- Click Here!
    Ran into some trouble Mike S Original Mariah Talk 14 05-26-2009 06:05 PM
    Engine trouble grommett Original Mariah Talk 5 04-26-2009 09:09 PM
    Trim trouble shilo Sea Fox - Mariah Talk 5 02-20-2008 02:24 PM
    Having trouble with avatar shilo Introductions 3 01-27-2008 07:10 AM
    trim trouble aquaknot Original Mariah Talk 5 08-13-2007 12:17 PM
    There are 265 users
