dual battery setup?
howdy all,
I'm looking to add a dual battery setup on my 240z talari. I have the big red selector switch so far, but nothing else. Do I need to use a battery isolator on this? I havent installed anything yet and I want to do this right. I feel safer running two batteries in case one dies while I'm in the middle of the lake, plus I have a 7.4 engine that I'm sure has a heck of a current draw when starting up. Has anyone upgraded to dual batteries that can give me some pointers on doing this the right way? Thanks, Paul |
Re: dual battery setup?
Lots of threads on this paul if you do a search.
You don't have to use a isolator but it sure is handy and advisable. :) Here is a kit from Blue Seas. ADD-A-BATTERY |
Thanks, Larry. I'll check it out!
1 Attachment(s)
I have a new on in the box if you are interested in that particular model.
Sent from my DROID RAZR HD using Tapatalk |
Absolutely worth the money to put in the isolation setup. Much better system than the old 1/2/combine/off switch. Just turn it to on and it takes care of charging both batteries while either running or on a plug in charger. A few years ago, I installed that setup on my shabah and this spring I will be replacing the switch on my Jubilee with the same setup.
I still have one up for grabs...
Motoxxx, do you still have it for sale? havent been online in a while- cruddy satellite internet's been on the blink
Yes, I still have it. $100+shipping.
motoxxx, i'll pm you for info. would like to buy one
| All times are GMT. The time now is 10:59 AM. |
