Trailer question asap input needed Thanks!
Old 07-11-2013, 02:30 PM   #11
Default Re: Trailer question asap input needed Thanks!
That's IF they're adjustable. A little hard to tell from the pics, but they don't look like they are... Usually adjustable ones use u-bolts, which I don't see, or maybe my eyesight is going with my old age. What I can see though is, that trailer was made for an Astro bass boat, and if you've ever seen one, they are very low profile, and have a different hull design, so I'm not sure if it'll work or not. You definitely don't want bunks sitting on your strakes, especially while trailering. If the bunks are adjustable though, it shouldn't be a problem. But the winch post might be a little low, so you may have to consider replacing that? The price is good, I'm just not sure if a bass boat trailer would be right for your boat. It's just my opinion, but maybe you should keep looking?
The general rule I've always seen is 20+ boats use tandems. Looking at the Chariot Trailer brochure from 1997 (Mariah's in-house trailer company), the trailer they recommend for the 202 is a tandem axle. They even used tandems for the 19 footers.
  • Old 07-11-2013, 03:17 PM   #12
    Sharp eye Chris...........sharp eye.
    Old 07-11-2013, 06:51 PM   #13
    Andy b's Avatar
    Andy b is currently offline
    My Model: Diablo 180
    Gallery Images: 9
    Send Andy b:
    As Chris has pointed out the dead rise on that trailer is way to shallow for a 20' Mariah
    I know things are slightly different over here in the UK but even my 180 is on a twin axle trailer.
    Old 07-11-2013, 08:04 PM   #14
    gahooligan's Avatar
    My Model: 202
    My Engine: 5.7l
    Send gahooligan:
    Found a tandem. Fully adjustable. Picking it up tonight for $1100. Thanks for all the help and thanks for saving me from a huge mistake!!
    Old 07-11-2013, 11:27 PM   #15
    voodoo's Avatar
    voodoo is currently offline
    My Model: Davanti
    My Engine: 5.7
    Send voodoo:
    Originally Posted by gahooligan View Post
    I have to go pick up a trailer tomorrow to enable me to pick up the 99 Mariah 202 I am purchasing from a local dealer (no trailer included or available for sale). I have seen these on single and dual axle trailers. I found this single axle that has potential to get me the brakes I want. I have experience towing but don't know squat about boat trailers. This thing had a 21 foot on it. Please tell me if you think this will work, if you tow a 20 ft 2500lb Mariah on a single axle, etc. The guy will take 750 for it. The only other option I can find is a non matching blue dual axle for 1200... and I can't really afford to spend that much. I do however need a trailer that will work for my boat. I know my buddy has` been pulling his 20ft bayliner (cringe...) on a single w/ no brakes for 4 years with no issues. My tow vehicle is a 2000 Durango r/t 5.9l 4wd. Thanks for the quick help guys. I have no time to make an error on a trailer purchase. Here's the one I'm looking at $750
    19 to 21 Boat trailer
    Good call on the dual axle.
    A 20 footer is a big pull for a Durango, let alone on a single axle trailer.
    Dual axle means you can get some balance. The dual axle trailer is just that a trailer..not a teeter totter taking weight off and on your Durango.
    My Mariah is only 2 feet longer. No way I'd go single axle, Even a 5000lb axle. I've not seen a single axle trailer with brakes.
    I have a 2500 GMC long box crew and it knows my boat is behind it. I went so far as to swap the factory Eagle trailer to electric brakes from the factory surge.
    Old 07-12-2013, 01:54 AM   #16
    Excellent choice gahooligan!
    Old 07-12-2013, 06:03 AM   #17
    gahooligan's Avatar
    My Model: 202
    My Engine: 5.7l
    Send gahooligan:
    I bought the tandem, its ugly to me and will really clash with the boat!! (that's what paint's for) and hey, I can't see it from the water... One big drawback, I have to add brakes... not too happy as I thought it had brakes installed... However the tandem is a good starting point and should work fine for now. the rest of it's in pretty good shape considering it was in a field with a junk 20ft sea ray on it. I was in a pinch as I have to pick up the boat tomorrow after work. Thanks again for all the help.
    Old 07-12-2013, 06:36 AM   #18
    rainman55343 is currently offline
    My Year: 2003
    My Model: sx 19
    My Engine: 5.7 alpha 1
    Send rainman55343:
    Good luck
    Old 07-12-2013, 10:42 AM   #19
    gahooligan's Avatar
    My Model: 202
    My Engine: 5.7l
    Send gahooligan:
    Originally Posted by rainman55343 View Post
    Good luck
    What exactly do you mean there??
    Old 07-12-2013, 07:31 PM   #20
    My Year: 2003
    My Model: sx 19
    Send rainman55343:
    It will be a good trl and good luck with everything.
    Prestige trailer question SKMARTIN6 Trailering and Tow Vehicles 2 09-20-2012 05:22 PM
    Trailer Jacking Question newbie Original Mariah Talk 6 12-30-2011 08:32 PM
    Help! Need Input! Water Temp Gauge Diagram or Advise! Snoopinrob Original Mariah Talk 8 07-20-2011 06:54 PM
    trailer question rico Trailering and Tow Vehicles 1 06-10-2011 05:13 PM
    trailer needs repair/ question??? Lakeside Trailering and Tow Vehicles 6 05-19-2011 12:25 PM
    There are 336 users
