Open Bimini
Old 04-22-2017, 01:23 PM   #31
Paul F's Avatar
Paul F is currently offline
Gallery Images: 4
Send Paul F:
Default Re: Open Bimini
I bought an aftermarket without stainless hardware for a couple of hundred dollars. It's high enough for me to stand under and it has rear supports that can easily be removed for trailering. Problem with a small boat is when you set the angle so it doesn't catch the wind, it looks really tall on the boat. I added a second set of attachment points to the rear do I can leave the frame up at a lower angle when not using the top. It looks a lot better that way.
Firestone and GaryDoug like this.
  • Old 04-22-2017, 04:49 PM   #32
    ROY850 is currently offline
    My Model: 202 Shabah
    My Engine: 4.3L alpha one
    Send ROY850:
    You have any pics of it installed I'm doing mine today. I purchased stainless swivel mounts just in case and rear supports.
    Old 04-22-2017, 09:45 PM   #33
    GaryDoug's Avatar
    GaryDoug is currently offline
    My Model: Z202
    My Engine: 5.7L Bravo III
    Send GaryDoug:
    That's a great idea. And I happen to have an extra set of mounts to use so I think I will do the same.
    Ooops, looks like I already have a set there. great.
    Old 04-22-2017, 09:48 PM   #34
    GaryDoug's Avatar
    My Model: Z202
    Send GaryDoug:
    That's what I used to remount the top. Do you meant like these?
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Firestone and ROY850 like this.
    Old 04-22-2017, 10:46 PM   #35
    Send ROY850:
    Those are it!
    Old 04-24-2017, 01:30 AM   #36
    Send ROY850:
    Well finally installed my Bimini I purchased from national bimini tops, got it for a steal they had it in sale when I purchased it. Anyway here's what it looks like installed. Very easy I wish the mounts went on the inside instead on the out.
    Paul F, Firestone and GaryDoug like this.
    Old 04-24-2017, 02:01 AM   #37
    GaryDoug's Avatar
    My Model: Z202
    Send GaryDoug:
    Looks good. I wanted mine mounted that way so I could drop it in front of the windshield. That's the only way I could put on the boat cover without removing the top altogether.
    Old 04-24-2017, 02:17 PM   #38
    Paul F's Avatar
    Gallery Images: 4
    Send Paul F:
    I've never had any luck posting photos on this site, but if you go the Mariah Owners Facebook Page and search my posts, you'll find mine and see why I added a second set of attachment points. There's also a photo of my friends Z272 that I added a bimini to a couple of years ago. His came with telescoping support poles so you could adjust the angle. Problem is they're either to tight to telescope or too loose and wind would pull them out.
    On my Talari, I had to mount inside the windshield so I would lay it flat to put it in the garage. On the Shabah, I mounted to the windshield frame to it would lay flat to the gunwale and he could put his cover on.
    It also allows me to lay it flat and put up the convertible top in case of rain.
    I posted on Facebook on July 15, 2013.
    ROY850 likes this.
    Old 04-24-2017, 10:33 PM   #39
    Send ROY850:
    Yeah you're right, it makes it easier to take it down toward the front. That's actually how I ended up doing mine. I tried laying it flat to the back but it kind of interfered with the windshield. Let me ask you this Gary, do you have issues with the wind when it's up in the boot bag down the road, or you not even supposed to have it up when you travel?
    Old 04-24-2017, 10:38 PM   #40
    Send ROY850:
    I like the way you mentioned it, that's actually how I normally wanted to do mine but it was sitting up way to high on the windshield. I should have ordered the short Bimini and that could of worked, it would have sat lower and still been able to stand under it. Where did you purchase your Bimini?
    Hatch won't stay open kriswd40 General Maintenance 4 05-30-2013 01:27 PM
    open sea martin182 Original Mariah Talk 3 03-06-2012 04:35 PM
    Motor Won't Open Up ? TMRoper1669 Mercury MerCruiser 2 07-07-2010 01:11 AM
    Looking to buy a Mariah Open Bow rickdee Introductions 2 01-19-2010 01:47 AM
    z272shabah open bow loaded garyg Introductions 1 08-23-2009 07:59 PM
    Total Threads: 13,324
    There are 415 users
