Fariah Gauges
Old 05-28-2013, 03:09 PM   #11
Bill's Avatar
Bill is currently offline
My Model: Z222
My Engine: 496 HO Bravo lll
Send Bill:
Default Re: Fariah Gauges
Thanks Mickyt
I will check this out when I can get in the water Probably in august when it is warm enough lol
But I will check the electrical connections next time I am in the boat
Regards
Bill
2001 Z222
  • Old 05-28-2013, 05:06 PM   #12
    Originally Posted by Bill View Post
    Thanks Mickyt
    Regards
    Bill
    If you take a small compressor and disconnect the tube-line at the back of the speedo then blow air from the speedo back to the outdrive it usually clears any obstructions and will show you precisely where the pressure point is located on the outdrive. Usually its just a bit of gunk buildup.
    Bill (05-28-2013)
    Replacing Gauges douglas Original Mariah Talk 2 08-17-2011 04:46 PM
    Crazy Gauges injected1 General Maintenance 5 08-12-2010 04:12 PM
    Gauges john sinclair Boating 101 2 07-30-2009 12:09 AM
    Mariah Gauges jeffryb Original Mariah Talk 2 04-20-2009 01:43 PM
    Useful Info on Fariah Depth Sounder Z275 Original Mariah Talk 11 05-28-2008 10:17 PM
    There are 341 users
