Fuel Tank in 94 Z220 Talari
Old 09-20-2012, 09:46 PM   #1
kruthes1's Avatar
kruthes1 is currently offline
My Model: Z220 Talari
My Engine: 350 Mag Alpha1
Send kruthes1:
Default Fuel Tank in 94 Z220 Talari
I am having issues with my fuel guage. It reads empty all the time. I just topped the boat off so I know it is full. When I turn the key on the guage goes from completely bottomed out to the "E" mark so I do know that there is voltage to the guage. I suspect the sending unit. I couldnt find a service hatch. Just wondering what I have to do to access it.
Thanks in advance
94 Z220 Talari
350 Mag Alpha1
  • Old 09-21-2012, 01:27 PM   #2
    Default Re: Fuel Tank in 94 Z220 Talari
    I'm not familiar with your particular boat but if you follow the fuel filler line down to where it goes under the floor you should find the spot where you can access the sender unit. My guess is there is a flap of carpet covering it.
    kruthes1 (09-21-2012)
    Old 09-23-2012, 06:26 PM   #3
    PlumLazy's Avatar
    PlumLazy is currently offline
    My Model: 210
    My Engine: 5.7, Bravo III
    Send PlumLazy:
    Thanks in advance
    On my '94 Z211 Shabah, I can tilt the back seat forward and there are two aluminum trim strips holding a carpet flap and access door down just in front of the engine in the center of the floor. I can remove the trim strips and there is a hinged hatch in the floor right there for access to the sender and pickup in the top rear of the tank.
    hope this helps.
    Bob
    Canyon Lake, TX
    '94 Shabah Z211, 5.7 Bravo III
    Thank you PlumLazy for this useful post!
    kruthes1 (09-23-2012)
    Talari fuel tank capacity Snowaterdude Original Mariah Talk 10 08-24-2016 07:10 PM
    New to me 94 Z220 Talari kruthes1 Introductions 2 09-16-2012 02:48 PM
    fuel tank capicity and fuel milage talari z Boating 101 2 08-01-2010 12:01 PM
    fuel tank capicity for 1995 talari 190 z talari z Introductions 1 07-15-2010 09:50 PM
    Z220 talari fuel capacity scott3558 Original Mariah Talk 2 07-20-2009 02:10 PM
    There are 337 users
