Questions about 1991 mx20 mariah
Old 08-20-2012, 12:02 PM   #1
SKMARTIN6 is currently offline
My Model: 182 Shabah
My Engine: 4.3 v6
Send SKMARTIN6:
Default Questions about 1991 mx20 mariah
Need some advice. I'm looking to buy a 1991 mx20 that was a trade in at a local dealer. The gelcoat and interior are in excellent shape. Engine is a 305 cobra w/omc outdrive. Talked to the original owner, he said the engine had around 1000 hr's on it had regular maintance with no problems so far. The dealer is asking 6100 for the boat can probably get it for around 5500. My question is are the hr's to much for this motor and outdrive and have not heard many good things about the omc outdrive. The boat would be used mostly for just cruising around the lake. Any help i could get would be greatly appreciated. Thanks
  • Old 08-20-2012, 01:44 PM   #2
    Default Re: Questions about 1991 mx20 mariah
    1000 hrs on a '91 is a lot unless it was recently rebuilt. If you are really serious then i would suggest having the compression checked by your own mechanic and you need to get the boat onto the water to see if it performs properly. I'm not a fan of OMC Cobra outdrives. IMHO i think $6100 is high for that boat.
    Old 08-20-2012, 01:57 PM   #3
    My Engine: 4.3 v6
    Send SKMARTIN6:
    Thanks for the reply. The omc outdrive is my biggest concern, everyone i have talked to about them said the same thing. I myself no nothing about them. I did a search and read an article that said the biggest problem they had around that time was the shifter cable would get out of adjustment and would cause the gears to grind an wear out. I asked the guy that had the boat about it, he said he would adjust the cable each spring and never had any problems. But with my luck that would be the first thing to go an the outdrives are not cheap. Again thanks for the input.
    1991 MX20 Stern Heavy???? bworner Original Mariah Talk 2 07-10-2012 01:02 AM
    1991 Diablo Upgrades Questions kelster1574 Original Mariah Talk 7 03-24-2011 06:50 PM
    1991 Mariah MX20 FOR SALE mranderson Mariah Boats For Sale & Wanted 2 07-31-2010 11:13 PM
    New member - Mariah MX20 for sale in TN TN MX20 Mariah Boats For Sale & Wanted 0 07-27-2010 09:10 PM
    1991 Mariah MX 20c 180diablo Mariah Boats For Sale & Wanted 3 01-28-2008 08:14 PM
    There are 311 users
