Season Over....
Old 08-21-2012, 01:37 AM   #11
DougR is currently offline
My Year: 2003
My Model: SX 20
My Engine: 5.7
Send DougR:
Default Re: Season Over....
Wow, totally missed that you had a small block already!!
I had to do an engine swap last year... Yes it costs money but you can have a lot of fun doing it....
  • Old 08-21-2012, 01:45 AM   #12
    truckingeorgia79's Avatar
    truckingeorgia79 is currently offline
    My Model: MX 200 Talari
    My Engine: 5.7L Alpha I
    Send truckingeorgia79:
    I've already been looking at all the options out there. Been also doing more research on the "Hydrolock", it seems that replacing the riser gasket will fix the problem. The problem with that is where my manifold and risers meet there is rust at the seam. Does that mean they are bad and I should replace? Do you think after replacing those I will be fine as long as I don't have a bent rod or something. I need to get a leak down/ compression tester and see what the cylinders are doing.
    Jeremy
    1993 Mariah MX 200 Talari/ 5.7L Alpha I
    Old 08-21-2012, 02:33 AM   #13
    My Year: 2003
    My Model: SX 20
    My Engine: 5.7
    Send DougR:
    Rods are really strong!! Either way you'll be better replacing if you think they're shot... You may be able to use the engine after an oil change etc...Or you woudn't want to risk a new motor???
    Old 08-21-2012, 03:26 AM   #14
    The problem Jeremy is the bearings. It ain't whether they will go.......it's when. I got fresh water risers that will work on your manifolds if you want em. You pay the shipping and they're yours.
    However , I'd be really leary of that motor.
    I'd keep what ya got , bore it over .030 , cleanup the ports , maybe step up the cam a notch or two at the most , and put her back together with all new internals.
    Larry
    truckingeorgia79 likes this.
    Old 08-21-2012, 04:01 AM   #15
    Larry
    That's what I have been thinking about doing. I think I will also be getting new mainfols and risers (if they look bad when I take them off) just because they have been on there since 1993. Larry, if I need the risers I will let you know. Thanks
    Jeremy
    Old 08-21-2012, 04:07 AM   #16
    No prob Jeremy.
    Be safe on your deployment and we'll talk to later!
    Larry
    Old 08-25-2012, 08:32 PM   #17
    Well removed both risers and exhaust manifolds today. Definitely looking at a complete rebuild before I go back on the water. I found out that not having the exhaust flappers installed will cause a lot of water to enter the manifold and head, from the looks of it the flappers have not been there for some time. The port flapper was completely missing and the starboard flapper was half there. The inside of both heads from what I can see is covered in "rust". Not sure if I will be able to salvage them yet. The port manifold so far looks like I might be able to salvage, but the starboard one well no. While I was removing the bolts to remove the riser, 2 of the bolts were rusted so bad that they snapped off inside the manifold. Now to try and find a deal on some manifolds. Will post some pics later today or tomorrow.
    Jeremy
    Old 08-26-2012, 03:04 PM   #18
    Well here are the pictures of both Port and Starboard Heads. Pics go from left to right Port - Starboard. My only ? is, does anybody think these heads are salvageable?
    Jeremy
    Old 08-26-2012, 03:14 PM   #19
    Here are pics of both Port and Starboard Manifolds and Risers. Pics go left to right Port - Starboard. As you can see on the Starboard manifold, the bolts were rusted so bad that 2 of the bolts broke off inside the manifold. Hopefully I can just get those drilled out.
    Jeremy
    Old 08-27-2012, 01:01 AM   #20
    husker_fan's Avatar
    My Model: 192 Barchetta
    My Engine: 4.3L Alpha I
    Send husker_fan:
    If the heads aren't cracked, always salvageable. That looks like not much more than surface rust.
    Sent from my SCH-I535 using Xparent ICS Blue Tapatalk 2
    Season Opener! Kitto Original Mariah Talk 3 06-07-2011 03:35 PM
    End of my first season Tilted Original Mariah Talk 3 10-27-2008 02:43 PM
    First season with Talari 180 Tom Introductions 2 08-09-2008 06:31 AM
    First Launch of the Season! CameronBrian2120 Original Mariah Talk 15 04-08-2008 01:22 PM
    Boating season moondance100 Boating 101 32 12-10-2007 01:43 AM
    There are 300 users
