Using power tool near engine/depth finder
Old 07-16-2012, 07:35 PM   #1
jjk61083's Avatar
jjk61083 is currently offline
My Model: 202 Shabah
My Engine: 5.0L Alpha One
Send jjk61083:
Default Using power tool near engine/depth finder
I am replacing my Lowrance depth finder with a new Faria. The Faria transducer, unlike the Lowrance puck style, has a separate base that is first attached to the hull and filled with liquid. The separate transducer is then attached to the base with a twist lock. The current hole below the engine where the original transducer was is about 2 - 2.5" round. The new one requires a hole at least 4". My question is, will it be safe to use a power tool such as a Dremel to enlarge the hole in the fiberglass being so close to the engine. Even though the boat hasn't been run for a couple of weeks there is a little gas smell. I can't imagine trying to do it by hand, but I wouldn't want a spark to possibly occur near the gas. Has anyone had experience with something like this? Thanks.
Jim
1998 Mariah 202 Shabah
5.0 Alpha One
  • Old 07-16-2012, 08:08 PM   #2
    Default Re: Using power tool near engine/depth finder
    I just run the blower for about 5 minutes before starting work and i've also had a habit of setting up a small house fan to blow fresh air into the engine area.... and i'm still here.
    Old 07-17-2012, 01:30 AM   #3
    jjk61083's Avatar
    Send jjk61083:
    Thanks Mikey. We are all glad you are still here!
    Jim
    5.0 Alpha One
    Depth Finder issues gly101 General Maintenance 1 06-10-2012 02:57 AM
    Depth Finder jchestnutt Introductions 1 05-06-2012 12:16 AM
    Depth finder inop theeasynine Original Mariah Talk 24 09-06-2010 05:45 PM
    Depth finder woes NogginDoc Boating 101 1 07-19-2010 04:35 PM
    Depth finder joeboat Original Mariah Talk 1 08-21-2009 12:54 AM
    There are 213 users
